wagler mechanical belt tensioner
KyleC4
470
Bay Area
you're right Bdsankey, when I talked to Andrew from wagler about this he said these belt tensioners were being specifically designed for the guys turning some rpm with duel fuelers. So if they say they don't have one for an lb7 yet I'm going to wait til they do. i'm sure they know that the gm part number from 02-10 is the same but they've tested and figured out why it doesn't work on 02-04 lb7's rather that being geometry, etc.
ZeroGravity58, thanks for that info as well since you experienced this already with an 01.
byeezy_lb7
Reno, NV
Wagler belt tensioner
Finally installed the wagler belt tensioner for the lb7.... no more belts getting shredded
KyleC4
470
Bay Area
Nice :thumb: Yeah austin sent me an email saying they’re ready but forgot my truck is an 01. So I’m on the hunt for an 02+ alternator bracket
2,020
Have you stress-run the truck WOT upwards of 3500+rpm after the install to see if it really does help solve the belt throwing?
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I put one on mine. Definitely a quality piece.
byeezy_lb7
Reno, NV
Nice. Good to know.
I spoke To soon.... I was Messing around with boosted launches and now that my motor is broken in I decided To see what my truck would do with a boosted launch with the wagler tensioner installed and belt still slipped off.... not sure what else I can Do to keep the stupid belt from coming off
1,187
Have you checked the pulley alignment? On the gas side we see this on trucks with blowers. usually comes down to a misalignment issue
byeezy_lb7
Reno, NV
I haven't had any belt shift since getting their tensioner. I'm not saying their tensioner is the "be-all-end-all", but some form of rigid tensioner is what these trucks need with RPM and dual pumps. The factory tensioner doesn't seem to have enough force.
I know Duramaxzak has made his own version of a manual tensioner using some off the shelf parts that seems to be working well for him (LB7). The info is posted in his build thread (LINK).
I just installed the wagler tensioner and my belt still slips off under a heavy load...
6,024
How much tension are you putting on that belt.
The longer the belt, the more it stretches. Manual tensioners are ok if you know how tight the belt has to get after it’s hot and stretched some.
Spring tensioners take that guess out. Problem is getting a heavy enough spring or enough arm throw
Harbin_22
3,858
Southern Indiana
It's so crazy that I have never had a single issue with belts coming off. I've had a PPE dual fueler kit for probably 50k miles of constant beating lol. Even has a 10mil for the top pump
buick455
55
Knock on wood I haven't had any issues either with a factory tensioner even running a 12mm pump on the belt. It's hit almost 6500rpm more than once (never on purpose) and still never came off. Used the same standard belt for 5 years. This is a 2001 LB7 using ppe dual fueller kit. Hope I don't have issues now after saying something lol.
byeezy_lb7
Reno, NV
your lucky hhahah my belt comes off anytime I go above 4500rpm even with the wagler belt tensioner..
stealthy_max
Jan 10, 2015
27
Midwest
We’ve found the Dayco tensioner works good. It has a metal pulley with shoulders on both sides. Multiple years of 5k+, zero belt issues to date.
