Are there any disadvantages of using stock retainers? I wouldn't imagine the weight would make a difference on a piece that small.
Those are the only 2 that people seem to use.
Hamilton's you can use your stock retainer's
SoCal you have to buy there retainer's, but you can get Titanium ones to reduce valve train weight.
They don't list them on their site.
I believe these are the springs Curtis put in my heads. 130 lb IIRC.You Upgrade the retainers to titanium for strenght not weight lol. You don't want the increased spring pressure to rip the valve stem through the retainer!!
The comp cam valve springs are the same beehives that fit the 32 valve 4.6 Ford v8's in a mustang. That may help with a spring supplier. I have a supplier for springs I use that work very well also.
You use Ti to reduce weight Titanium doesn't always mean stronger...
The lighter the valve train the lighter the spring pressure has to be, which equates to less pressure on the cam lobes and less wear and tear on the lifters... Also you can use a lighter spring and not float the valves as early...
I may see what I can round up from Manley.
The valve springs are upgraded to handle higher boost/drive or lift and engine speed. Or to match a cam.
The rest of the valve train is there to support that modification.
Not the other way around as you suggested.
Why would you upgrade retainers to decrease spring seat pressure?
Or did I totally misunderstand what you intended there?
