Nope. The return line is bolted to the head where the return fuel comes out of the head back to the tank.
I think Dura-RAtion was referring to the FPRV, not sure...Are you referring to the FPRV? I think the early trucks had a banjo bolt instead of what we have on our lbzs... You got a link to RLD's test? An injector would be better than a Cp3 like you said, I've been saving for a injection pump because I couldn't think of anything else it could be
not a prob, I only spent $40, compared to GM's $166 test, and I found a leaky injector.Hmm I should probably look at doing this before anything else.. Thanks for the info bud
Ahh see that $166 now. Hmm How do I command the rail pressure to climb during testing with live?
but as far as testing for return flow, I don't think this is what you want to do.Ahh see that $166 now. Hmm How do I command the rail pressure to climb during testing with live?
No this is not for the test. DVT function is for a different "test".I thought I needed to do this in the test? Maybe not. If not would I just hook up the lines and disable the FCIM and crank it over for 15 then measure the cups?
Good deal, hope you figure it out.Gonna take it to the dealer tomorrow probably for the test. I made a run today to see what kind of pressure I hold... To my surprise the lowest I saw was about 22 on the Stealth 2, but I still got the 87 code. I really don't know what to think now, I figured It would be wayy lower than that, maybe I have I'm just crazy and don't have a fuel problem boost only hit 27 though still.
Bottle test came up clean, I'm pretty sure the highest it commanded was 29k, but the desired was around 26 when it was at its lowest actual pressure. I shoulda logged it but owell I was just off driving around and the S2 is still in the truck so tested it out. The fuel filter is was changed about 20k ago, Will get that changed this coming oil change
not yet. should soon though.Have you changed that injector yet Jeromy? It sounds like you may have found your problem. I kinda figured you might have something like that going on.
There is nothing wrong with 26K
I'm sorry I messed up on typing that, it was a Miller night... The highest it commanded was 29k.
The lowest actual was 21-22K and that was while it desired 26k I believe, like I said I didn't actually data log it but rather glancing at the Stealth 2 thought so I could be off.
Anyhow the low rail pressure code popped up at about 100 mph as always.
I can get you a PPE race valve...try it out for a week or two, see if it fixes your problem. If not I'll personally buy it back from ya.:hug:I'm sorry I messed up on typing that, it was a Miller night... The highest it commanded was 29k.
