ugggggggg!!!!!!!!!! my turn for a break down :(
3,733
305
Got under the truck to get it in park and make sure it would start. Noticed orange dust above where the front driveshaft was bent. And there's orange marks on shaft. I think I hit a brick. There was a busted in half brick within feet of where we found the rear driveshaft
That sucks. Might want to tell that to the insurance company, it might help.
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Yea, a stupid $0.99 brick.
Friday they said an adjuster would call first of the week. I called at 4pm and got voice mail. Left a msg crying about out of work, a trailer sitting in the driveway that was supposed to be in Quebec last week, etc
Glad its a side job...
Progressive Commercial - anyone got Flo's #?
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Flo showed up today
Talk about lowballing it
For the dents in exhaust, they said they would order 4inch pipe and have it bent. I said noone around here will be able to bend it. Oh no, chevy garage can do it. I said nope. Sure enough they said 'I called 4 shops and noone can bend 4inch pipe'
So here's what they think they're gonna do: cut out the 2 dents in the exhaust and weld patches over the holes!!!!!!!!!! WTH!!!!!!!!!!!!!!!!!!!!
They have body labor rate priced at $46 an hour?!?!?!
And (thanks again mike L) Progressive thinks the tail housing can be replaced without taking the trans out. I talked to chevy garage about it and told them what you said MikeL, service manager said he really didn't know what to say because they've never seen one busted open, and would have to fix it how the gm service books say to. So let's hope its in the book to pull it out
I'm out of whiskey :(
3,733
305
Dang, that sucks. Don't back down with Progressive, just keep telling them what they NEED to pay for.
I had a similar claim with them and they tried everything possible to get out of it, but I didn't back down, and in the end, they paid for everything. Took a bit of work, though...
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Does anyone have a link to the gm specs on how to replace the transmission rear housing on a 2wd lbz?
I think Henry has a pm coming...
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Isn't it nice how we pay out the ass for insurance so they can "patch" our stuff back together?
Try pricing a commercial road-trip type policy. Just lowered all coverages I could since truck won't be driven for a while and its still higher than we pay on the wifes jetta and the van
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
You shouldnt have to fight a company that we pay for to cover us in the event of an accident Pisses me off,had a girl hit me that was uninsured and that kicked in my uninsured underinsured coverage....you would think i had double and tripple coverage rite? NOPE! turns your insurance into their insureance.My insurance found me 25% at fault which made me pay for 25% of damages:angry5: Now i know why my company is self insured.
ripmf666
15,123
14
47
Wentzville Mo
As Mike told you there going to have to remove the trans to do this.
Service Information
<FORM method=post name=CellHandlerForm action=/si/cellHandler.do>
2007 Chevrolet Silverado - 2WD | Sierra, Silverado VIN C/K Service Manual | Transmission/Transaxle | Automatic Transmission - Allison | Repair Instructions - Off Vehicle | Document ID: 1833861 <HR>
Low and Reverse Clutch Piston and Output Carrier Assembly Removal
  1. Notice: Refer to Torque Converter Housing/Low and Reverse Clutch Housing Bolt Size Notice in the Preface section.
    Important: Remove the low and reverse clutch housing - 4WD using the same procedure as when removing a low and reverse clutch housing - 2WD.
  2. Remove 4 bolts (1).
  3. Remove 12 bolts (2).
    Notice: To help avoid damaging the park pawl return spring, make sure the park pawl support pin is not retained in and removed with the low and reverse clutch housing.
  4. Disengage the low and reverse clutch housing (1) from main housing locating pin (4) and pawl support pin (5).
  5. Remove the low and reverse clutch housing (1).
  6. Remove and discard the gasket (2).
    Caution: Always remove or install the output carrier assembly by holding onto the output shaft. Holding onto the output carrier assembly instead of the output shaft may allow the output shaft to fall causing personal injury and/or property damage.
  7. Remove, as a unit, the output shaft (2) and the output carrier assembly (1).
  8. Remove the output shaft (2) from the output carrier assembly (1).
  9. Remove the output sun gear (4).Important: The thrust bearing assembly may stick to the output shaft or the output sun gear.
  10. Remove the thrust bearing (3) from the output shaft (2) or the output sun gear (4).
<A href="http://gsi.xw.gm.com/si/showDoc.do?laborOpCode=&docSyskey=1833861&cellId=119852&pubObjSyskey=1833861&from=sm&pubCellSyskey=119852#ss1-1833861">Park Pawl Removal
  2. Disengage the park pawl return spring (2) from the transmission case (4).
  3. Remove, as a unit, the park pawl (1) and the park pawl return spring (2) from the park pawl support pin (3).
  4. Remove the park pawl return spring from the park pawl.
  5. Remove the park pawl support pin (2) from the transmission case.
  6. Remove the park pawl cam guide (3).
  7. Remove the low and reverse clutch piston return spring assembly (1).
© 2011 General Motors. All rights reserved.
</FORM>
ripmf666
15,123
14
47
Wentzville Mo
Service Information
2007 Chevrolet Silverado - 2WD | Sierra, Silverado VIN C/K Service Manual | Transmission/Transaxle | Automatic Transmission - Allison | Repair Instructions - Off Vehicle | Document ID: 1564273 <HR>
Low and Reverse Clutch Housing Assembly Disassemble
    Important: The low and reverse clutch housing, 2WD and the low and reverse clutch housing, 4WD are disassembled using the same procedures except as indicated.
  2. Remove the retaining ring (1).
  3. To remove the output carrier support bearing assembly from the low and reverse clutch housing, 2WD on a 2WD transmission, perform the following procedure:
    <TABLE border=0><TBODY><TR><TD vAlign=top>2.1. </TD><TD vAlign=top>Position the low and reverse clutch housing, 2WD (1) on the press so that the inside of the housing is facing down.</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top>2.2. </TD><TD vAlign=top>Press the output speed sensor (OSS) reluctor wheel (2) and the output carrier support bearing assembly (3) from the low and reverse clutch housing, 2WD.</TD></TR></TBODY></TABLE>​
  4. To remove the output carrier support bearing from the low and reverse clutch housing, 4WD on a 1000 Series™ 4WD transmission, perform the following procedure:
    <TABLE border=0><TBODY><TR><TD vAlign=top>3.1. </TD><TD vAlign=top>Position the low and reverse clutch housing, 4WD (1) on the worktable with the inside of the housing facing down.</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top>3.2. </TD><TD vAlign=top>Using a drift, tap the output carrier support bearing (2) from the low and reverse clutch housing, 4WD.</TD></TR></TBODY></TABLE>​
  5. Position the low and reverse clutch housing (1) on the work table so that the inside of the housing is facing up.
  6. Gently pry the low and reverse clutch piston (2) from the low and reverse clutch housing (1).
  7. Remove seal ring (1) and seal ring (2) from the low and reverse clutch piston (3).
</FORM>
ripmf666
15,123
14
47
Wentzville Mo
Service Information
2007 Chevrolet Silverado - 2WD | Sierra, Silverado VIN C/K Service Manual | Transmission/Transaxle | Automatic Transmission - Allison | Repair Instructions - Off Vehicle | Document ID: 1275478 <HR>
Low and Reverse Clutch Housing Retaining Ring Replacement
    Important: DO NOT replace the retaining ring in the low and reverse clutch housing unless:
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>The retaining ring is damaged.</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>The low and reverse clutch housing is to be replaced.</TD></TR></TBODY></TABLE>​
  2. Position the low and reverse clutch housing (2) on the worktable so that the inside of the cover is facing down.
  3. Remove retaining ring (1).
  4. Install a new retaining ring (1).
  5. Make sure the retaining ring is seated.
</FORM>
ripmf666
15,123
14
47
Wentzville Mo
Service Information
2007 Chevrolet Silverado - 2WD | Sierra, Silverado VIN C/K Service Manual | Transmission/Transaxle | Automatic Transmission - Allison | Repair Instructions - Off Vehicle | Document ID: 1227251 <HR>
Low and Reverse Clutch Housing Assembly Assemble
Tools Required
J 36850 Transjel® Lubricant
  2. Position the low and reverse clutch housing so that the outside of the housing is facing down.Important: The low and reverse clutch housing, 4WD does not contain an output speed sensor (OSS) reluctor wheel.
  3. For 2WD transmissions, install the OSS reluctor wheel (2).
  4. Gently tap the output carrier support bearing assembly (3) into the low and reverse clutch housing.
  5. Install the retaining ring (1).
  6. Install seal ring (1) and seal ring (2) onto the low and reverse clutch piston (3). Lubricate the seal rings with J 36850 or an equivalent lubricant.
  7. Position the low and reverse clutch housing so that the outside of the cover is facing down.
  8. Align the tang on the low and reverse clutch piston (2) with the tang hole in low and reverse clutch housing (1).
  9. Install the low and reverse clutch piston.
</FORM>
lotsofmiles
Father of the Van
Dec 4, 2008
3,097
Michigan
Thanks you very much Henry! Service manager couldn't find it yet.
So the 'housing facing down', means just like Mike L said, trans needs to be out of truck to do it?
And the title says 'off vehicle'
I'm assuming ins man is going to have to ok pulling the trans
Cougar281
1,830
268
St Louis, MO
You sure the brick hit the driveshaft? Seems unlikely the brick could have hit the driveshaft and caused that much damage. It seems more likely the u-joint let go and the driveshaft hit the brick on the ground.
Sent from my SPH-D700 using Tapatalk
