Ok guys need some a little help from all ya Duraburb gurus..
To data log the transmission output shaft I'm adding a magnet ring and pickup on the driveshaft yoke. Plan was just data log that RPM vs Engine RPM with V2. However can't seem find any description on bringing a pulse sig in on the AD inputs.
So I did a little digging, and looks like a T42 TCM could be hacked to at least data log output shaft speed, pressure, and temps pretty easy and capture ECM and TCM data with the V2. With a little work, and the proper TCM OS, it seems the T42 can do tap shift via pin-10 input. This was used only on the 05-07 GXP. while majority of cars used the BCM and canbus commands. This may also been used on some Corvette platforms, but I know from experience the canbus data on the Vette up to 2014 is totally different from all other GM platforms.
If could find a GXP 4L80 OS, or similar, then it's possible I could control the shifting of BOTH transmissions using the T42 TCM fed via single GPS speed input signal. Basically setup the TCM tune as a "2-Spd" ,, ditch all the DTC , line pressure controls, and such. Then set both units to shift by Speed only, or Speed and RPM, and possibly incorporate the Shift Torque Limiting features at the same time..
Thoughts?
