twins/ single
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
My oil temps never even changed 5 degrees by adding twins:thumb: But i do not tow anything so im sure towing yes they do heat the oil up more but for DD twins really had no effect on my oil temp. or A/C one bit.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Just FYI's LBZ+ dont see much of an oil temp issue influenced by twins nearly as much as LB7/LLY. Like Pat said, a poor mans oil temp gauge is to watch the oil pressure gauge. With my twins, before a cooler, I could see 270* towing up 6% grade for 5-10 miles. Oil pressure then would be ~30psi @ 2500rpm. Highest vie seen with a cooler is 225* towing 13k to Mike L's.
Those with AC issues, have you removed the charge, and added the correct amount, or even serviced it at all? Proper AC maint. should be serviced every year. I dont have any AC issues, 110* plus here.
