Twins for what
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Since there is so much turbo talk going on (confusing too) I have a questionz.
What the necks the point of spending the big bucks on compounds to run 10's? If they can be ran with a 75 mm charger(ie. Gt4202) alone ? Usually if that's what your shooting for with twins , the 75 becomes the small charger and you have to add an even bigger turbo just to run what the 75 could run alone. Or is the point of compounding just to reduce spool up?
ku 808
164
How come the fastest diesel on the planet run twins?and the most power till date dyno Duramax was with twins:hello:
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
So your saying a built motor with a gt4202 will be just as fast as built motor with a gt4202 feeding a gt 55 ??
Other way around hoss. He's saying that theres no way that an S475/S366 (or the like) twin setup, could never flow more air than that same S475 as a single.
Reason being, the 475's flow path is bottlenecked by the S366.
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Exactly, thats why you don't see anyone in the unlimited single class 3.2 twins running twins, the big singles flow more than the same combo with a small charger to disturb flow. Stingpuller,camomax,casper have all ran into the 10's with a single turbo. Many ways to skin a cat comes into mind on this subject:thumb:
Drholliday
286
Gresham, OR
Thats simply b/c they are running a small turbo that is bigger then most would run as a single turbo simply b/c if they didn't have that turbo the truck would never be able to spool the large 110mm or larger turbo as a single.
But.... hypothetically speaking... if you have a single S510 and could spool it. it would make more power then the same charger as the big one in a twin set up.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
The reasons for twins:
More efficient exhaust gas energy recovery, however this is offset by higher compressor losses.
Higher peak boost levels, however this is offset by mechanical limits of high cylinder pressure, and lower peak HP RPM.
There are almost always trade-offs when doing modifications; there is seldom a free lunch.
xcablb7
Feb 8, 2009
536
Fall River
I don't think I could make over 800 with my 4088 alone, nor would it be any fun to drive with just th 4718, I put twins on to make a best of both worlds kinda comprimise low egts, great drivability can tow whatever and still have between 8 and 900 rwhp
