twin setup?
juddski88
Freedom Diesel
Jul 1, 2008
4,658
126
Chesterfield, Mass.
i found these specs for a turbo for sale here in Mass for $500.....It's supposedly a GT42 that was rebuilt close to some GT47 specs:
T4 flange
88mm inducer
118mm extruder
5" compressor inlet
v-band compressor outlet
6 bolt down pipe flange
1.22 hot side
anyone here know Garrett turbos and can shed some light into how this might work as a secondary? I figure i might swap it for a t6 flange but other than that.....
maine04max
Dec 11, 2008
1,009
hey Tim , Just an extra $3K for a 7.1 ? id like to get your discount :hug: lol but seriously sound like you have some killer plans for your truck :rockon:
juddski88
Freedom Diesel
Jul 1, 2008
4,658
126
Chesterfield, Mass.
glad to hear you got your tranny in and it's working out for you. I was at Foster's last sunday. I bought that 07 motor from him and will be storing it in an oil bath while i'm gone. i figure i can budget ahead and say that if i do most or all of the work myself with the help of RCS Diesel and this forum, I can achieve a very strong 1000+hp motor for under 20k. I know it's a ways out, and i'm not getting my hopes up too much, but i am planning ahead for it and getting things while they are cheap. i am looking forward to working with Big Dipper on the tranny, whether i keep the allison or go for the duraflite, when the time comes. i was thinking i might just put mild tranny and small twins on before i left and now that i have had to suddenly do some body work:mad: i am going to do that the way i really want it the first time and not do it twice. I want to be able to more than just build this truck too when i come home, so i am going to be bargain hunting a lot for the little things.
maine04max
Dec 11, 2008
1,009
well you know im only a phone call away if you need help . not that im expert but many hands ................
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
T4 flange
88mm inducer
118mm extruder
5" compressor inlet
1.22 hot side
IT SHOULD SPOOL SUPER FAST AS a secondary. what primary do you have right now?
juddski88
Freedom Diesel
Jul 1, 2008
4,658
126
Chesterfield, Mass.
will be..:) thanks Vaz for your input...i think $500 is a pretty good price for this turbo so even if i have to have it modified later i might have what, $1000 into it total? that's not too bad i don't think for a Garrett.
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
smokin deal! anyways, i would ty it as a single to see how shit spools:D i came across another good deal too today, a s362, with a dual wastegated 80 a/r housing for $350 all fully rebuilt
black 5
Jun 3, 2009
OK guys. I will be doing a full revamp on my truck. Motor build, twins, dual cp3's, and trans. The question I have is can I run a S366/S488 combo with with T4 housings on both? The reason I want to run the T4 housing on the 488 is I want to go with a procharger eventually and I need a T4 housing so I can move it to the top charger.
Is that a good combo or is the bottom charger too big or top charger too small?
Jun 28, 2007
3,259
NE Pa
You could always run a t4 to t6 adapter when you change over.
black 5
Jun 3, 2009
That is a big turbo to begin with, wont I run out of room under the hood with that spacer?
Other than that will those turbos work well together? I was gonna run 1.1 and 1.32 A/R's respectively.
