The assumption your making is that people are overspeeding a vvt top charger. Can you post any tech to back this up? Most setups I've seen have been running that bottom charger at a higher pressure ratio that the top. That would put the bottom charger at more of a risk for being oversped
Correct, I cannot back this up without a compressor map. But you cannot back up your argument without a compressor map either.
In case of the bottom charger overspeeding why not put a bigger one on?
