Twin guys, let's see your passenger fender liners
thunder550
1,176
Phoenix, AZ
My fender liner is nowhere even close to fitting with the new twin kit. Trying to figure out what to do with it. Anyone have pics of trimmed or reshaped fender liners to share?
ScreaminDuramax
Sep 19, 2013
345
Torrance
I don't have a pic, but I used a heat gun and molded it the best I could around the downpipe. It ended up hitting the down pipe and melting it around the heat wrap. Which actually worked out well because I cleaned up the melted edges trimmed a little extra off and now all you see is a little heat wrapped pipe sticking out of my fender :thumb:
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I tried the heat gun technique.. Got mad and took a razor to it and made a little window.. If you stay on city streets that's fine. I did a lot of dirt road and my downpipe stayed nasty
NJ_LLY
Back in action
Nov 4, 2008
560
Browns Mills, NJ
I'll be doing mine this week and the plan is to heat the piss out of it then put some of that silver heat deflector pads on the fender. Also heat wrap on the dp.
5,839
Mines gone. i have one on the shelf i keep thinkin of trying to make work. that down pipe gets hot towing and finally melted in half when i was towing brian back from ABQ long while back.
always ment to try the heat gun idea and line the fender by the pipe with heat tape, its just not a high priority yet.
CaptPhil
1,012
Delaware
What fender liner.....
jacobdewey
This won't last long...
Jan 14, 2011
972
It takes a lot of patience to mold it. That being said... I cut mine. lol Just take your time with a heat gun, and you will be able to shape it. You'll like it better than cutting it.
56taskforce
1,081
56
Cut a window and make a sheet medal pan secure it to the plastic liner with pop rivets.
baggedLB7
Goer
May 1, 2011
688
Utah
I used a heat gun and didnt think it was hard to do. But I had my old melted fender and laid it over the new one and lined out the melted area so I new were to push. I also put down some reflective heat tape.
It has been holding strong for a year and a half.
plowboy_lbz
Farmer
Aug 6, 2013
431
Don't have a pic but mine fits good. Be sure to use a 1/2 ton inner fender. They are smaller than the hd's. I trimmed some and used a torch to mold it then used sheet metal screw.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I have to run a liner, the roads up here a are so filthy that my engine bay would be wrecked... Besides the runs to the lower 48 I have made through Canada...
In Az though you might be able to get away with it. However you seem to be the kind of guy that likes his stuff clean.
Jacobs liner looks pretty nice:thumb:
9,903
149
HD 1/2 ton or regular 1/2 ton?
