is there anyway to do a compressor wheel upgrade using the same turbo ? i know may not be to much diff but for sure alot cheaper just a though
There was talk of upgraded wheels on another board. Wasn't one I frequent so I don't recall which.
i think he was talking about the stock turbo
Here's a suggestion Justin. A PPE set up for a GT42 turbo w/no turbo. Then get a S464 from Airwerks with a .90A/R T4 exhaust (should have the 83/74 turbo side). The intake is easy to fab and you can probably use most of you existing parts for the intake. This turbo will be up gradeable to a 70mm, 72mm, 75mm, 80mm+ if needed in the future. It will run with a HTT turboed truck with this set up. Just a suggestion though. You wouldn't regret it. You can get into this for around $2200 straight up or even less with a few connections.
there was quite a bit of talk about it over on DF.....i know there is one at least in the testing stage not sure if its available yet for sure though
Last i heard he hasnt got them finished up yet.
Last I heard it was 2k for both sides being upgraded ? Seemed high to me ......
I know there was someone on the DF that was making new comp wheels for the LB7 turbo and i believe it was $150 plus shipping. Supposed to make it spool faster and run more boost.
i tried to find the thread on DF but the search over there sucks big time compared to the one over here...
the guy you wanna talk to about the wheel in question is SN "Timespentsearching" but his first name is Freddy...over on DF
but i did find out its a 64.5 mm compressor hes working on/selling...not sure about turbine side
