A Road Runner is a bit quirky until you figure out what you need to do to make it work in various vehicles.
Mine works fine, it will set an occasional security light and hiccup every so often but it works and works well.
DieselMafia,
The rattle is most likely caused by fuel pressure at part throttle not timing.................try reducing fuel pressure 5-10 mpa in the area of the tune where it is rattling.
Remember time/pressure/orifice is key.
You have a larger orifice so depending on pressure you get more or less fuel delivered as well as pulse width.
You will need to increase pilot timing and main injection timing to compensate and probably lower fuel pressure.
Also increase pilot pulse width and main injection pulse width at idle.
White or blue smoke is incomplete combustion, you need "more" fuel to complete the burn and more timing.
Communicating was not the problem. Repeatability was
was. Pull after pull on the dyno it never did the same thing. Put in the old ECM problem solved. SmokeShow had the same troubles.
As for the injectors. Different ways to skin a cat. I like to pull timing. Bump down the pilot and add pressure. Use Josh's calculator to see where you offset is to make sure you not way out in front.
At Idle I don't like to increase the pulse widths. Adding some pressure accomplishes the same thing (adding fuel) and makes for a cleaner burn. The white smoke is not lack of fuel always. It can be fuel that never really got lit to to poor atomization. Fuel haze at idle is a classic example. Even with stock injectors you get it. Not uncommon to see warm idles with main shot timing after TDC. Not all trucks like that. Bumping that degree by degree out of the negative can clear the smoke and smooth the idle.
