Well I have DELIPPED lb7 pistons, the nozzles, Ported heads, nothing real special bigger Turbo ect
how much have you DELIPPED? whats the compression at now? and if im right the lower compression will also play a role in how the fuel burns.
ok let me get this right,the smoke is now at 1000-1200 rpm when its cold?
is the motor building boost at this point? if so how much?
if its not keep pulling PW out at that rpm range.
boost helps the fuel burn as well also if no boost,its hard to burn all the fuel your putting to the cylenders,because of lack of air.
to see what im talking about take a 20oz bottle,and a match,light the match,hold it inside the bottle,it will go out,when it runs out of air,yes their is fuel in the cylenders,but theirs way to much. the air to fuel ratio is still wrong.
yes you can change timing a little like maybe 2-3* but then with as much fuel its putting in the cylenders,it mite start to knock,because the pistion will becoming up on the compression stroke. . . im kinda in the dark because i dont have the tune your runing.
and i know their is a way to take a screan shot of the table with efi live but i cant remember how!
if you want send me the tune you were using BEFOR you started to mod the tables. send to
[email protected] ill see if i can help you out a bit
i hope this helps
