Fwiw warranty goes off build date not sure why but that's what i got told by gm but at least your injectors are easy to swap and can do just one not a set
Well that lasted a day doing the same $hit again
come by sunday kevin and lets go for a drive
If it is draining the rail that much, pulse should go up that high. Look at tge pulse table and you will see it in the bottom left corner.
My truck would do this when it was stock with a dirty fuel filter. Need a vac gauge to test at the factory fuel port.
I agree with Harbin. When pressure drops, pulse goes up, especially when it gets that low. You should pull the stock tune and take a look at it. It should be easy to see if it has been changed.
If you can have Steve look at the tune and give me his feed back. I may need to do the bottle test and check the vacuum at the gauge port
I am real close to giving the truck to the wife and taking her car :roflmao:
Just dont go WOT and your good
lol its sent. hes out workin on his GFs car
