I cannot flash either one. Will my cts or autocal check communication with ecu and tcm unplugged?
not sure on that. think it would . here is a pin put for the tcm check the powers and gronds
Transmission Control Module (TCM) (MW7)
Connector Part Information
- OEM Connector: 13551663
- Service Connector: 88988934
- Description: 80-Way F (BK)
Terminal Part Information
- Pins: 6, 9–11, 20, 25, 27, 33, 36, 40, 47, 51–52, 55, 60, 63, 66, 69–71, 74, 78, 80
- Terminal/Tray: 33012-1002/26
- Core/Insulation Crimp: E/C
- Release Tool/Test Probe: 12094429/J-35616-14 (GN)
- Pins: 14, 17, 34, 43, 53–54, 57–58, 73, 77, 79
- Terminal/Tray: Service by Connector Assembly - See Part Catalog
- Core/Insulation Crimp: Not Available
- Release Tool/Test Probe: Not Available
Transmission Control Module (TCM) (MW7)Pin
Wire
Circuit
Function
1–5
Not Used
0.5 TN/BK
2500
High Speed GMLAN Serial Data Bus+
7–8
Not Used
9
0.8 BK/WH
451
Ground
0.5 RD/WH
1840
Battery Positive Voltage
11
0.5 OG/BK
1228
PC Solenoid Valve High Control
12–13
Not Used
14
0.35 GY
773
Transmission Range Switch Signal C
15–16
Not Used
17
0.35 PK
1224
Transmission Fluid Pressure Switch Signal A
18–19
Not Used
20
0.5 L-BU
1984
Transmission Turbine Speed Switch Low Reference
21–23
Not Used
24
Not Used
25
0.5 OG/BK
6399
Replicated TOS Signal
Not Used
27
0.5 TN
2501
High Speed GMLAN Serial Data Bus−
28–32
Not Used
33
0.5 YE/RD
1223
Shift Solenoid 2 Valve Control
0.35 WH
776
Transmission Range Switch Signal P
35
Not Used
0.5 BN/WH
2469
PC Solenoid Valve Low Control
37–39
Not Used
40
0.5 L-GN/BK
822
VSS Low Signal
41–42
Not Used
0.35 D-BU
5985
Accessory Wakeup Serial Data
44–46
Not Used
47
0.5 TN
2501
48–50
Not Used
51
0.5 OG/WH
2527
Shift Solenoid C Valve Control
0.5 L-GN
1222
Shift Solenoid 1 Valve Control
53
0.35 YE
772
Transmission Range Switch Signal B
54
0.35 YE/BK
1227
TFT Sensor Signal
55
0.5 L-BU/WH
1229
56
Not Used
57
0.35 OG
1226
Transmission Fluid Pressure Switch Signal C
58
0.35 TN
2762
Low Reference
59
Not Used
60
0.5 PU/WH
821
VSS High Signal
61–62
Not Used
0.5 PK
2139
Ignition 1 Voltage
64–65
Not Used
66
0.5 TN/BK
2500
67–68
Not Used
69
0.8 BK/WH
451
Ground
70
0.5 RD/WH
1840
71
0.5 BN
323
Actuator Supply Voltage
72
Not Used
73
0.35 TN/WH
771
Transmission Range Switch Signal A
74
0.5 D-BU
1530
Transmission Mainline Pressure Solenoid Control
75–76
Not Used
77
0.35 L-GN/BK
2529
Fluid Pressure Switch Signal 4
78
0.5 BN
418
TCC PWM Solenoid Valve Control
79
0.35 D-BU
1225
Transmission Fluid Pressure Switch Signal B
80
0.5 OG
1983
