truck towing pictures...
06_6.6
Haulin Assphalt
Sep 3, 2012
159
Indian Territory
Small compared to the loads on here. Mostly form wood with a few pallets and a roll of filter fabric. Made the rear squat pretty good.
Sent from the land of teepee's and buffaloes
624
been on the fence for a while now bout one.. found one 07 ls lmm 4x4 its ~300lbs lighter then the current truck.. biggest selling point is the 20-40% mpg increase over current setup
624
yes in the prosess redo the engine swap in a Allison and air ride the rear
and most of all be able to run to make to pay off debt!!!
624
Any aftermarket plans for the new rig or are you going to keep it stock?
egr/dpf delets,scale the tps to my liking add timing, same style fuel filter setup, lift pump better fuel cooler and oil cooler, setting up the back much like my 99, later date large tank from either titan or transfer flow (56gl) allowing me to run none stop for 8 hours regardless of load. braces on steering system as well, gauges natually
rmallen30
861
15
hillsboro ohio
Nice ! Congrats on the new rig
