truck just got rear ended by a drunk @ 1515
620
Is the bottom rear most part of your frame bent upwards? If so, what caused that Adam?
the last ~6" is the bumper bracket and curves upward from the actuall frame
different angle of same bracket it is a stamped steel peice... probly set up as a crush zone :( there are 2 bracket that run from the frame to the corner of the bumper skin... skin and brace was the only thing bent.
hopefully those are a better shot of it
lawrence: yes i was.. hammered the bolts in with a 4# baby sledge then tighted them with a 1/2 ratchet then 1/2 impact... got maybe another 1/4-1/2 on them with the impact
620
bumper is done and mounted.. used less then 1/2 sheet of 1/4" plate.. turned out better then expected... got a couple thing to finsih up "bolts and paint job"
will get pics up shortly as i get them off my cell phone:(
620
they wrok for me... they are myspace links
still have the revese flood lights and licsens plate light to wire up and paint of course the studs broke so we are goignto use flat head bolts instead fastenal aint open till monday.. :(
620
seeif i can do it this way just for you ;) :hug:
you see the attachments?
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
All the pic's worked for me. Looks good!
Does the bumper stick out past the end of the hitch? That could be an issue with a sled hitch.
You can take the orange sticker off any time now!:D
620
yes it does but less then and 1"
8 bolts and the bumper comes over rather easily dont think it will be a problem;)
TX23
Wanna Race??????
Mar 5, 2008
354
San Angelo, TX
Looks great...wonder why we pewter trucks seem to have a run of bad luck getting rear-ended these days.
If I knew how to weld, that would be what I'd want...Sad, I work for a steel company and have no idea how to weld.
Good looking bumper and hitch.
