Triple CP's anyone
2,097
That is pretty impressive, Ken.
I havent read the entire thread yet, so bear with me: Is the third CP3 just used to keep rail pressure at the level you're currently running....or is it going to be used to increase rail pressure even higher?
IdahoRob
Jun 5, 2007
1,151
Trying to keep max pressure the same, but increase volume to hold that pressure with the new injectors.
2,097
Gotcha. Thanks.
You guys need to find two or three LML CP4.2s sooner than later.
13,765
834
Looks pretty awesome guys. Looking forward to hearing about how it does.
Nathan, I think my plain smooth pulley needs to be updated to the fancy new pulley design. :cool:
9,906
152
If you don't mind me asking, who made up the fuel lines to fit the 3rd CP3?
Idaho CTD
Junkie
May 28, 2008
179
Idaho
I made the lines. I didn't have a line short enough to make it somewhat straight so I had to put a loop in it. I'll order a new line that's shorter once we're sure it works good.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Seems my two partners were busy last night installing the third cp setup we've had on the shelf all summer. The latest injectors are big enough to finally start to cause a loss of rail pressure so the new setup is on. Nathan has been itching to do this since we got the controller from ATS early this summer. Rob is suppose to send me some pictures this afternoon and I'll post them up. Having to redo the MITUSA lift pump bracket right now. Rob is putting on the slicks and will be at the Halloween Classic at Firebird this Saturday.:thumb::happy2:
ken...................you are insane...................
I like it. :D
ben
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I like the pic guys,Nice fab work!
The fuel lines are they thicker wall than stock or the same? I would like to hear more about them if thats not a secret:) Are you bending and adding the connection or getting them built?
Hows the controller working? No issues?
Rob is racing this weekend? I wish best of luck to beat the 9.94!!!
Are you guys going to get more serious about suspension or are you not considering anything in that department?
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
This truck is stll a work in progress, Rob is running right now, couldn't get the fuel line to stop leakinf from the third cp so took it off and running the twin cp's for now. Having a bitch of a time getting it to hook on the cold track. We need a line lock so we can at least get the back slicks hot. Ran a 140.38 with a very slow 60 and having to peddle. HP is not our issue. We are still working on the suspension, have all but two leafs out of the back, sway bar and QA1 shocks all around and the front chained to limit how much it will lift.
If we could get this damn thing to hook it would run mid 9 easy.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
They are always a work in progress:D How about using tire heaters?
I realize HP is not your guys issue:cool: I am changing my suspension big time this winter in hope to get 1.4 60s, Sadly it is going to add wieght that I didnt want to do.
Congrats on the 140 mph guys that is incredible for the wieght of the truck!
