LBZ: Trip to dealer goes SOUTH!
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
The truck looks modded is part of the issue Im sure - triple gauges, lifted on 35s, SoCal switchplate, tint, exhaust, full stereo, etc.
Also something that didnt help was that the truck went in extremely dirty :(
I want to get the truck back, clean the engine bay up REAL good and then do a compression test and look over the motor. Then check coolant levels and oil sample and go from there. I think itll be time to do valve cover gaskets and some little stuff, but Im almost positive it wasnt HG.
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
They have already blocked his power train warranty
and your point?? i had a 8.1 that had motor problems they voided my warranty went to a different dealer to get a second look at were the regional rep just happened to be visisting and confronted him my motor got warrantyed no qusetions after that just start shit man dont back down an roll over kick some ass :thumb:
Cougar281
1,827
264
St Louis, MO
On the LBZ they can read the Tq on the TCM.
Now on what you posted For RPOs LLY and LBZ only: Calibration ID Numbers and Verification Numbers from the Vehicle Information screen.
The service tech is told to take a screen shot of the tech2 and Gm will tell the dealer of the last 10 calibrations it had also its just alittle harder to do then the newer truck.
I'd be interested in seeing the procedure to obtain that info from the LBZ ECM....
ripmf666
15,123
14
47
Wentzville Mo
It wasnt a point I was making the others had not seen the vin check were GM already blocked his. Know how long ago was it when you confronted the Rep. Yes he has a case to fight but I would have the rep come to the dealership. Also I bet you confronted the rep a few years ago before the new Gm also it was a 8.1 not the diesel Gm is killer on not doing the warranty work on them for the smallest part if you piss the wrong one off you might end up without a warranty at all before your done or be fighting it for a very long time.
ripmf666
15,123
14
47
Wentzville Mo
2005-2007 RPO LLY and LBZ Instructions for Confirming Calibration Verification Numbers (CVNs) -- Power-up Kit Detection
  1. Important: In order to process an engine/transmission/drivetrain WARRANTY CLAIM , you MUST photograph the required Tech 2® screen information BEFORE disassembly or removing the engine/transmission/drivetrain components from the vehicle.
    <LI type=1>Go to TIS2WEB <LI type=1>Select: Calibration Information (SPS Info) <LI type=1>Enter the VIN <LI type=1>Select: Get Cal ID <LI type=1>Select: ECM Engine Control Module <LI type=1>Select: Next <LI type=1>Select: Complete History <LI type=1>Print <LI type=1>Take the printout to the vehicle along with the Tech 2® <LI type=1>Plug in the Tech 2® <LI type=1>Go to diagnostics and build the vehicle <LI type=1>Select: Powertrain <LI type=1>Select: Engine <LI type=1>*Select: Engine Control Module <LI type=1>*Select: Module ID Information or I/M Information System if Module ID Information selection is not available. <LI type=1>*If: I/M Information System was selected in step 15, it may be necessary to select: Vehicle Information in order to display the calibration information. *Steps may vary by engine controller.
    <LI type=1>Compare the Calibration ID and Calibration Verification Number (CVN) to the CVN shown on the TIS2WEB printout. Although the part numbers will be the same for each, it is the CVN that will determine if the calibration is GM issued. The CVNs should be the same.
    <TABLE border=0><TBODY><TR><TD vAlign=top>⇒</TD><TD vAlign=top>If the CVN information is displayed as "N/A" , it will be necessary to contact the TCSC to obtain the CVN information. </TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top>⇒</TD><TD vAlign=top>If the part numbers match and ANY CVNs DO NOT match the printout, it is likely that a non-GM certified calibration has been installed. </TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top>⇒</TD><TD vAlign=top>If ALL of the CVNs are EXACTLY the same the calibration is GM issued. </TD></TR></TBODY></TABLE>​
    <A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2367363&releaseDate=2009-11-09&name=Identifying+Non-GM+ECM+Calibration+Usages+and+Power-Up+Hardware+Detection+for+Duramax+Diesel+Engines-Photograph+Tech+2+Calibration+IDs+and+CVNs+and+Trans+Data+Scree#oth2-2367363">Vehicle Information Screen
  2. Take clear digital picture(s) of the Tech 2® Vehicle Information screen(s) showing the VIN, the Calibration IDs and the Verification Numbers. Retain the printout information and the Tech 2® screen photographs with the repair order.
    <TABLE border=0><TBODY><TR><TD vAlign=top>18.1. </TD><TD vAlign=top>E-mail copies of the digital pictures to [email protected]. In the subject line of the E-mail include the phrase "Duramax™ diesel", the complete VIN and Dealer BAC. In the body of the E-mail include the VIN, mileage, R.O. number and BAC. Include a brief description of the customer concern and cause of the concern. </TD></TR></TBODY></TABLE>​
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Note: The dealer will receive an email reply after the calibrations have been validated. The email reply will advise the dealer if the calibrations are OEM. </TD></TR></TBODY></TABLE>​
    <TABLE border=0><TBODY><TR><TD vAlign=top>18.2. </TD><TD vAlign=top>Allow two hours for the PQC to verify the calibrations and set up the case details. </TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top>⇒</TD><TD vAlign=top>If the PQC determines that the calibrations ARE aftermarket calibrations, DO NOT contact GM Technical Assistance to discuss warranty concerns on the aftermarket calibrations. ALL questions and concerns about warranty should be directed to the dealers Fixed Operations Manager (FOM), (Warranty Manager (WM) in Canada).</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top>18.3. </TD><TD vAlign=top>You may call the PQC two hours after submitting the required information for authorization to replace the assembly. This will provide them time to receive, review the information and set up a case on the request. Be prepared to provide all of the usual documentation that is normally required when requesting an assembly authorization from the PQC. </TD></TR></TBODY></TABLE>​
13,744
817
How does the TCM calculate torque input? I thought it just went off what the ECM told it.
Cougar281
1,827
264
St Louis, MO
I will log into Gm and see if I can hunt it down and post it for you. Be later I have not been to bed since yesterday.
Ouch!
Looking at what you just posted, the history they're referring to is the TIS2Web update history. They're looking for you to match the CVN's in the ECM to one of those in the TIS2Web history for each section. There's no mention of the programming history for the LBZ. Not trying to argue... Just pointing out how the GM docs read...:hug:
twister773
livin the dream
Apr 14, 2007
134
central coast
If what you said about it seeing the last 10 tunes? couldn't you just tune it to stock 10 times and that would cover that problem? It seems tough for me to argue anything without having looked at the truck before i took it in. The thing that bugged me is he kept saying heavily modified, then he told me how GM spent millions developing the motor and that it should stay that way, and that it had too much compression, etc...the only two things i thought that could really cause too much compression as far as tuning was boost and timing? If those were kept stock what else could cause it. When i told him heavily modified? It only has exhaust and thats when he told me well we already sent the word into GM and we are waiting to here back. Im supposed to get the truck back today or they said Monday. Im leaving for Canada Sunday and get back thursday so wont be able to get the truck until Friday if they don't finish it today.
twister773
livin the dream
Apr 14, 2007
134
central coast
And you guys really think they are gonna prorate a refund on the warranty...they will say something about small print and how i voided it and cant get a refund.
Cougar281
1,827
264
St Louis, MO
Nope... It only tracks the last 10 changes, and alternating back and forth between two stock cals would be suspicious (not to mention it can't be done with a Tech2 & TIS2Web)... It's a moot point anyway as from what I can tell, the cal tracking is not there in the LBZ ECM's near as I can tell (although technically, the hardware can support it, it's just not enabled).
Too much compression just doesn't make any sense..... IMO, they're blowing pink smoke up your a**.... It's a real crappy situation they've got you in. It sounds a lot like there's nothing really wrong with the motor, but they're trying to trump stuff up and get more money, and in thinking that your truck is "heavily modified", have voided your warranty in hopes that you'll bend over and pay them to do the work...
IMO, just because someone has "triple gauges, lifted on 35s, SoCal switchplate, tint, exhaust, full stereo, etc." does not mean they've touched the motor... Not saying weather or not twister has tuned it, but I've seen many a truck with all of the above (except maybe the socal switchplate) but bone stock motor. Heck, the triple gauges most of us have are gauges the truck should have from the factory.
twister773
livin the dream
Apr 14, 2007
134
central coast
My truck has keys, isnt lifted, on 33s'. Has a boost gauge and pyro gauge. and the socal switch mount is for strobes in the truck...has nothing to do with engine.
13,744
817
What is the screen that is shown on the Tech 2 in Henry's last post? It looks like a list of Cal IDs and verification numbers from an 05 LLY.
Cougar281
1,827
264
St Louis, MO
It is, but it's the CAL ID's for the different segments (Operating System, Engine Operation, Engine, Fuel System, System, Speedometer, Boot Block & CPU). I verified that on my ECM. Each of those ID's & CVN's will match up with one of the segments.
13,744
817
It's hard to tell since the picture is cut off, but it looks like it says Engine before each Cal ID. :confused:
Cougar281
1,827
264
St Louis, MO
Correct. It does. That's referring to the engine controller.... If you look at the same screen for the TCM, there are two Trans lines. One for the OS and one for the CAL. I've gone down the list on my ECM and each one does match one of the segments from TIS2Web.
ripmf666
15,123
14
47
Wentzville Mo
There going to look to see if the verifiction number comes back to that truck in it history with updated from Gm. If the dealer has no record of changing the cal I'd that's were they have you with nothing should be changed other then thru the dealer network.
