i did my pump rub fix last week and put 2 quarts of transynd in after. today I noticed a whine coming from the t case almost like a slight whistle. it only seems to do when the truck at an angle like a small incline and the truck is idling
Many have had very good luck with 3qts of Mobil1 5w30 motor oil added after drain. Add through the top sensor hole.
Sent from my SCH-I535
Yes but I would like to clarify
- Add 2qts into the t-case fill hole with a hand pump, apply sealant on fill plug and install
- Then removed the speed sensor and add 1 qt through the sensor hole
- Replace oil every 10,000 miles
These were the instructions I got from Mike L. 3 quarts is about right but you want to be sure not to overfill.
