Hello all, I'm new to these forums and to the diesel life. I recently bought a 2007 Chevy 2500hd 6.6 duramax LBZ with the 6 speed Allison. Here recently one night on my way home from work it shifted hard down and went into limp mode into 4th gear(scanner said solenoid b stuck on). After reading on these forums looking for answers and reading all of mikes comments, I removed the valve body and like he had mentioned there was a little dirt/grit in there. I cleaned everything, put back together with new filters and fluid. Now the truck is running fine, shifts good with no codes. However before any of this happened my truck normally ran 150 degrees on the tranny, after I put back together I now have noticed that my truck drives close to 200 degrees on my way to work in the evening, and on my way home in the morning it runs as it did before at 150 degrees... Like I said I'm new to diesels, this is the first diesel tranny I messed with, so is there a problem or am I worrying about nothing??
