Trans temp concerns
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
It's on my list as well. Still have not heard back from Mike. Two voicemails, three calls to shop and one to cell phone all during business hours. Hopefully for him he is busy and I understand if so. Maybe he does not want an ATS customer to have his cooler? Hopefully he still wants to sell me a cooler. Brian referred me to Renodmax's idea with the Summit cooler and if I don't hear from Mike I guess I'll just go that route. The highest temp ive seen in five years with my tranny is 205 on a 98 degree day pulling my utility trailer through stop and go in the city. Track temps never pass 175-180 or so no issues there.
Nope I have a ATS transmission and his cooler. Hopefully he'll get back to you.
super diesel
<<<< Under Pressure
I was in belief that oil filters have a built in relief if they do clog? No?
Yes. However the stock oil filter housing on most models has a bypass built in it as well. I believe it's set to 63psi? You wont see that pressure at the dash gauge though unless you have a 01-02 with the sensor right after the oil pump. That just what it opens at. Now what the journals see after this another matter. I think they call it "residual loss"?
Mike L.
15,681
232
Fullerton CA
Michael, every filter manufacturer has different settings for the bypass. In the allison the spin on is critcal because it feeds control main pressure which feeds the valve body and solenoids. 125 psi in and anything over 126 psi gets dumped to sump because the solenoids can't handle it. If pressure drops at the spi on filter on the Alli, all hell breaks loose.
super diesel
<<<< Under Pressure
So sorry Mikie. I was speaking of the engine oil filter housing. So yes, what Mike said.
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
What a great thread filled with differing opinions/views/thoughts to ponder. All seem to unanimously agree a cooler WILL in fact help the temps. Wether or not oil can/will help? Jury is out. That said, if ever there was a thread prompting enthusiasts to upgrade to the "finest" tranny cooler ever made, this is it. Mike L can I please get a quote on a "Mike L/Setrab cooler for my 5 speed Alli? Thanks in advance. PM is fine or you have my number on the voicemails. Please don't gouge me on the price for publicly stalking you for a price quote lmao.:rofl:
Mike L.
15,681
232
Fullerton CA
Call me in the morning and I'll take care of you extra special. Sorry I left you hanging. No excuse.:hug::D
megaboz
Apr 8, 2010
20
All you know is what you read off a brocure and what has been fed to you. didn't you go off the deep end on another subject where you were banned?
You need a life; get one.
All the top name oils are great and you won't make a mistake choosing one. We all have our favorite oils because we experienced no problems using them. This does not mean yours is better.
I just remembered. you were the dick that was telling everyone you used Amsoil and changed your oil every 30,000 miles. WTF? What happened? Oil got a little dirty at that mileage? Let's hear it Richard.
Yea and seems that no one talks about that product anymore either? Coincidence? Odd?:confused:
megaboz
Apr 8, 2010
20
I am sure my last post is already going to cause crap, but oh well.
But riddle me this, "if" the tranny is already producing too much heat and is burning the oil (apply your own technical terminology), how would a cooler help?
I am not putting down anyone's product, nor supporting any other initiative, I do agree that if a cooler can keep ahead of the heat build up it is a good thing, but if the transmission fluid is already toast (again, apply your own technical terminology) before going to a cooler, I don't believe any amount of cooling that oil is going to reverse the damage to the fluids.
So theoretically, you need to reduce the heat that is being generated in the first place, better parts, better fluid, better/correct tolerances in the parts, better parts(material), better shift patterns(better computer programming for the transmission), etc... The cooler just helps to maintain that temperature, obviously adding something cooler to something hot will make things cooler. But if it already "too hot", isn't to late?
How much fluid actually gets pumped through the cooler and dumped back into the pan in any given interval? How much of a temperature differential is there? I have no idea, and this is a serious inquiry. I'm sure the stock cooler sucks compared to almost any aftermarket cooler.
Somewhere I read about upping the pressures to move more fluid, doesn't pressurizing actually increase heat? I'm not sure how that can help? Seems to me that more fluid that is cooled would be better, but it goes back to my question about the amount of "cooler" fluid returned to the transmission.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
And MikeL said that forget the fluid forget the cooler if your seeing excessive temperatures, you need to find the root cause as to why, not put a band-aid on it! BUT no matter what if your aren't seeing excessive temps any additional cooling will create longevity to the life of the fluid which will result in longevity to your transmission clutches and holding capabilities I assume.
megaboz
Apr 8, 2010
20
Apparently I missed the part about the "excessive temperatures" from Mike L., and maybe this is why (missed a post/misread a comment) the forums sometimes get blown way out of proportion, what I got out of all of this was that a "good" cooler would solve all the temperature problems.
I agree that keeping it cooler all the way around is better in the long run.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
I know what your saying this thread definitely went around like a sack of eggs! :D
Mike L.
15,681
232
Fullerton CA
Read post # 34.
