Allison 6sp: Trans Build, what clutch kit?
diesel53
Sep 16, 2010
907
AZ
Well I havent limped the truck but the converter is definitely hurting. Ill need my transmission built shortly. I have already decided to run Mike L's new TC but I do not know what clutch kit to go with. Looking to hold around 550hp, stock turbo truck. Ill probably run the truck around 450hp though. Im not doing any serious pulling or racing. Is a PPE stage IV good? Any better recommendations?
diesel53
Sep 16, 2010
907
AZ
Mike is not selling kits anymore, and he is too far away for me to have him do the build or I would. PPE stage IV holds 850 correct? What are the SC kits rated at?
Mike L.
15,681
232
Fullerton CA
Where do these crazy numbers come from? Even at the crank those numbers are unrealistic. At a 20% correction you have 680 hp at the wheels. A top builder will have to make a bunch of modifications to try and hold that with a stage 3 type kit.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
Jeez If I were only 6 hours away from Mike I would drive to the shop every so often just to annoy him....and hear the trains go by. :D
But in all seriousness to the original poster...make the drive to see Mike, its worth it knowing you have a first class trans that you will never have to worry about again. :thumb:
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,112
13
Phoenix
Diesel53, was your truck for sale on CL? I think I've seen it on there a few times. I guess you decided to keep it.
About the trans, just do a full stage 5 build and be done with it. No sense in spending the money to go half way.
On the Droid X
Sharks06LLY
May 15, 2010
115
Tampa Fl
x1000000
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
x3 on going to see Mike for the best route , if you do decide on kit only the GMAX kits are a good setup and would be plenty to handle what you want now and have some room to grow .
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
Like Mike said the PPE Stage 4 is equivalent to a SC Stage 3, which is rated at a realistic 500 rwhp. That means you can pretty much beat the crap out of it with 500 rwhp and still have it last. The right builder can easily get a stage 3 to hold 600 rwhp reliably with a few extra tweaks. Could you put down 680 rwhp on the dyno with a Stage 3? Sure. Could you beat the snot out of a Stage 3 with 680 rwhp daily? For a while, but it's not gonna last like it should.
The PPE Stage 5 is equivalent to (a knock-off of) the SC Stage 4 which is rated at a realistic 800 rwhp. Again the right builder can make it hold more with a few tweaks.
Dirtymaxx03
3,109
Go see mike man. If i wasnt in south texas, i would have made the road trip to let him build my trans. IIRC didnt brians old truck have a SCIII built by mike? and it held his 620rwhp.....
5,847
yes but brian is always scared of his trucks and that tune was only ran a handful of times
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
I don't see how 850 horse power isn't realistic. I can add just as well as the next guy. If you add factory horse power and box top manufactures horse power ratings for products I have purchased plus sticker horse power im probably at 1340 horse! My banks exhaust was 35 horse alone AFE intake another 50 horse! Plus my TTS sticker. That bitch is rated for a good 350 at the rear wheels and mister I got two of those bad boys anyone need one?:roflmao:
diesel53
Sep 16, 2010
907
AZ
Thanks for the input, Mike is about 11 hrs from me and I just dont have the time or I would have him do it.
Okay that helps, I was assuming that these hp/torque holding numbers advertised are somewhat accurate. So either PPE stage 5 or a GMAX kit are my options. Is there only one GMAX kit for a six speed? 6-3 is what I see around and its supposed to be the equivalent to the old SC IV?
Yes I was going to get rid of my truck but its not worth getting rid of an excellant running duramax.
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
I am running the PPE V with there convertor. I am running about 620 or so at the wheels. it works very well. I like it. convertor is a little rough at times daily driving.
05chevy
1,086
The gmax 6-3 comes with all your seals, valve body and pump mods. And I think ppe converters are repainted ML converters could be wrong tho
