Your other option I haven't seen mentioned is a remco lube pump. So long as your hooking it up for lights, you will have power as well, and can put a remco lube pump in to circulate oil through the trans with the engine off.
Ok Mike thanks for your input! We definitely will listen to your advice. So just to make sure I fully understand.... It is completely safe to tow with the t-case in neutral, right? And while t-case is in neutral the trans can safely be put in park so the key will be able to go to off position?
And another thing is I'm almost positive this truck has no steering wheel lock with the key off, if it does we will remove it. Learned that lesson the hard way once on a older truck, wrecked a set of brand new front tires...lol
Oh! I guess I'm a little confused here. With the t-case in neutral, drive shaft in place, and towing it that way.....are we risking damage to the trans or the t-case?No, I said I would never tow it with drive shaft installed.
I just realized that this afternoon...There is no steering locks on these trucks.
We don't need to lock it. If it had a steering wheel lock like the older vehicles we would need to remove it so the front wheels can "follow" us. If the ignition locks the steering wheel the front wheels just slide every time you turn, can ruin tires very quickly.If you need to lock the steering wheel, just put the seatbelt through the steering wheel and buckle it.
I'm confused on how the trans output shaft can turn if the t case is in neutral?
