This is why you need traction bars.
6,086
4-6 non torsion bar drop.
and he pulled a few leafs.
even without blocks and all the stock leafs you guys should see how much the pinion angle changes at WOT with a 500-up HP trucks. It would scare the heck out of ya and alot more people would be running traction bars lol :D
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
I had my caltracs off for grease and adjustment,...my dumbass forgot and rolled into it to pass a mustang and it was all bad news bears..
that said, i need to make up a link from the top of the axle housing to the rearward frame to stop wrap under braking.
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
I run these pro Comp bars,, look and work real good off road so far. as soon as the rest of the truck is done I'll test them out hooked to the sled,,
05chevy
1,086
you basically will disable the caltracs. it would be like running madmatts bars or what im running.
What if you had regular bars? The only thing I could think of would be a bind some wheres maybe just do a ladder bar and sliders?
6,086
what if i ran a 45* angle off the top of the axle housing?
doesnt matter. you completely stoping the differential rotation by that single bar. teh cal tracs need some axle wrap to increase pre-load on the springs. while its very minimal, adding that single bars stops it all together. adding it at 45* would give you weird stoping, starting conditions as well. Anti-squat would be too high
what do you mean? not following ya
Swisstyphoon
258
Ft. Lauderdale FL/Switzerland
Axle wrap is bad kids.
Sent from my iPhone.
Just checked mine the other day and :eek: it looks the same!
I think thats why I feel some vibration lately starting @ around 90mph and up.
Guess its about time to finally install the traction bars I have laying in my shop for quite some time now, before its to late!
What did you end up replacing? The whole shaft and yoke or just the U-Joint? I have to take mine out and inspect everything closer.
