This is how you weld
blownblue
Oct 22, 2008
61
Acme, WA
WOW, where would you start to with that being sooooo wrong and so bad.. I hope he doesnt sneeze so it doesnt fall off.
FMOS
Hard Up
Nov 19, 2008
352
Fort McMurray, Alberta, Canada
Wow...:rolleyes:
Why is this guy trying to show others? He clearly does not know himself.
For example: You would think he would at least get some terminology correct so that he sounds legit.... "basically you want to go up and down across there so you spread your feed out"... I think he was talking about running a weave bead... but its been proven that generally a stringer has better metallurgical and mechanical properties than a weave. Plus its harder for a welder to hide defects when doing a stringer. Hence the reason why most construction only allows stringers.
He's got a lincoln welder, he should buy the lincoln welding handbook for starters.
Jun 28, 2007
3,259
NE Pa
The guy actually welds better then 80% of the guy's @ work:), sad but true!.
he's good alright. Im actually on the road to nh right now for an emergency leak repair. I put in a call for 2 mirror tube welders....I wonfer if this yahoo is gonna show up to save the boiler lmao
Posted via Mobile Device
walsh450mx21
MR. MIDNIGHT
Aug 28, 2007
152
FLAWIDA
All i can say is WOW friggin wow.
1. buy a real welding helmet.
2. adjust the copper guard on end of welding gun to piece inside does not contact metal.
Those are just my recomendations.
FMOS
Hard Up
Nov 19, 2008
352
Well... there are many ways to make a sound weld. You can adjust the electrical stick out (copper guard around contact tip), wire feed speed (arc length) and your voltage to a whole host of different parameters and still manage to make a decent weld.
This guy has not only managed to screw all of those things up, he even did a terrible job of explaining how to do it the wrong way.
Yea, I say a proper welding shield is in order as well. I don't know many welders that do good work with only one hand... unless they have a few drinks to steady themselves out.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
I actually do Mig and Tig and stick one handed. When stick (arc) welding my left hand is getting the next electrode ready. When Mig And Tiging I just hold what I am welding or I steady myself.
Redbone
but this one goes to 11
May 1, 2008
261
Indy, IN
Couple of things.........
First, it's not a "copper guard", it's a nozzle.
Second, like BB88 said, many welds are done one handed. The position of the weld usually dictates what you do with your free hand.
Third, type of weld and material thickness will dictate how much you need to work the puddle by "stitching".
If anybody was gonna rip on this guy, I thought these things were ripe for target practice:
1) No mention of cleaning off the parent material.
2) Water quenching. Usually a no-no.
3) What's with the "grind it off" statement at the end?
Obviously not meant to be an all encompassing tutorial.
