What are the specs on the build :thumb:
Well with the stock motor, the mains spun..2,3,4 being the worst ones. So with this build I got a new gm crank and had it keyed, carrillo rods, mahle performance cut and coated pistons, billet main caps, main studs, all new clevite bearings, socal 6480 cam, socal damper, socal billet flexplate, arp flexplate bolts, head studs, ordering socal stage 2 heads, chromoly push rods, rocker shaft studs, new keyed oil pump, new welded water pump, new oil cooler, allseasons billet rear engine plate and I had the injectors bumped up to 100% from the previous 60% over.
