Things are starting to come along
xtremebikr04
Jan 17, 2011
573
Vermont
Just wanted to post some pics of what I went and picked up tonight:woott:
The flash from the phone made a couple of the cylinders look messed up but they're really not.
xtremebikr04
Jan 17, 2011
573
Vermont
Thanks guys, its been a long process but its coming along.
Did you have RAD do it?
I was going to but after talking with local people I ended up finding a machine shop less than 30 min away from my house that was very qualified to do the work. Im very happy with the service and end result.
xtremebikr04
Jan 17, 2011
573
Vermont
What are the specs on the build :thumb:
Well with the stock motor, the mains spun..2,3,4 being the worst ones. So with this build I got a new gm crank and had it keyed, carrillo rods, mahle performance cut and coated pistons, billet main caps, main studs, all new clevite bearings, socal 6480 cam, socal damper, socal billet flexplate, arp flexplate bolts, head studs, ordering socal stage 2 heads, chromoly push rods, rocker shaft studs, new keyed oil pump, new welded water pump, new oil cooler, allseasons billet rear engine plate and I had the injectors bumped up to 100% from the previous 60% over.
xtremebikr04
Jan 17, 2011
573
Vermont
Here are some more pics.
xtremebikr04
Jan 17, 2011
573
Vermont
Got the truck up and running and ended up having a little issue on the transmission on the first test drive. In the works on getting that fixed now. I'm pretty pumped to see what its got after everything is broken in.:D
