Sigh, still racking up those dollars.
Found my drive pressure leak.
The plan was for evan to swap the up pipes with stock one that I supplied but when he pulled off the stock one he found out the manifold will never seal. Apparently a couple up pipe bolts were broken off and then drilled out of the manifold. Very off center. To the point that getting a gasket to seal will be almost impossible. Soooo, evan is hooking me up with a set of ppe manifolds and up pipes.
Why a good set of stock manifolds and up pipes weren't installed during the motor build I have no idea. You can get them for shipping cost usually. Just more money I hadn't planned on right now.
Now this I knew about, but was told he broke it during the engine r and r. Serious race trucks don't need to check the oil. Gonna install a flexible dipstick.
