The White devil
andy-stevenson
Jul 7, 2013
838
Technically, it was his truck to **** up....
Not in his case it wasn't...
Well he was suppose to do head gaskets, studs, Trans, and s366. Summary, truck sat at the shop he was working for MONTHS, got it back the first time, return line went, fuel filled crankcase blew oil out front vent. Returned the truck, get the truck back, downpipe is hitting the firewall, rigged coolant tank, rigged battery setup in the bed, still had pressure on the cooling system.
Moved my batteries and got a oem coolant tank. Threw his shit out. Took my truck to a reliable shop in Salisbury, NC. Ended up finding almost every valve cover bolt stripped or damaged. Had an injector cup that was leaking that had no sign of any kind of sealant. So after another $5k the truck is fixed correctly. I have a whole box of bolts and etc that were stripped or damaged.
battlegraduate09
Gearhead
Mar 18, 2010
610
Ah. Thought he was talking of how the previous owner "built" the truck. I guess I'd be pretty pissed off too.
Wonder how this guy even worked on trucks ? I imagine him with a hammer and a crescent wrench with multiple tabs of "how to" and DYI threads opened on a laptop.
SparkZ03DMAX
Nov 16, 2009
866
North Carolina
Yep got royally screwed. Never see that money again. Truck doing great now, my only worries is the Trans cause I'm not entirely sure if its legit inside of not. But I've drove it and gave it some hell in my higher tunes and it hasn't shown any signs of anything bad. **knock on wood**
CaptPhil
1,012
Delaware
Here is a video of spool up on my truck. Cruising at 55mph or so and mat it. If I roll into it it will spool faster. Gets a little sputter if I mat it also, which you can hear. This is my dd tune, 1300us and 13° timing, 180mpa.
Top is atmo, middle is total, bottom is going to be drive, haven't hooked it up yet.
White Devil spool: https://youtu.be/uXGnw0vkpKc
CaptPhil
1,012
Delaware
Latest items, had to rebuild my brand new 366 already, redid the feed lines in the process. Thrust bearing was going out fast.
Need to redo my downpipe and go back to the stack, the side of my truck stays clean for about one day, then it is soot city, plus it smells bad all the time.
CaptPhil
1,012
Delaware
The 366s are fed with -4an lines.
It had oil restrictors in it before, now it is getting full oil flow.
CaptPhil
1,012
Delaware
Got around to making a new downpipe. This one is more suitably sized.
The old one had 3" pipes joining into a 3" pipe for about 18" before going to 4". Talk about restriction.
CaptPhil
1,012
Delaware
had a thought about something, would like to hear some opinions on it.
After I lost a 366 at the track I realized how lucky I was that the oil feed line had a restrictor installed, because it could have easily pumped oil into the intake and caused a runaway. instead it didn't even leak a drop off oil, even with the shaft destroyed and basically an open hole into the cartridge.
so considering I have three turbos and that air shut offs are stupid expensive, I had the idea of rigging a couple oil feed shut off valves. they would be cable actuated from the cab. thought being that if I were to lose a turbo I could kill oil to it and reduce the chances of a runaway. it would probably kill the other turbos, but rebuilds are cheap and easy compared to a built motor.
obviously this is not the best way, but like I said a few air blades are crazy expensive and take up a ton of room. I haven't seen this discussed before and maybe the chances of a blown turbo causing a runaway are very slim, but I am interested in hearing some thoughts on it.
Sent from my SM-G900T using Tapatalk
5,847
if you get enough oil in the intercooler before you notice a run-away, its still going to run for a while till enough oil burns off in the intercooler. the air blade is the quickest way to kill the motor.
i thought i read somewhere on how someone made a cheap one off an intercooler pipe
CaptPhil
1,012
Delaware
that is true, and the likelihood of a blown turbo causing a runaway is quite slim, was just something on my mind.
CaptPhil
1,012
Delaware
so I'm considering putting the truck back to stock and selling it off. the wife just got a new car and I have pretty much lost interest in beating on my stuff. since I moved I am a good drive from the track and don't really drive it on the street much anymore anyway. the truck is worthless on the street in anything other than the dd tune, and even that will roll the tires off at any speed under 50.
soooo gonna start looking for a complete engine and trans to swap in. I think I will get more money by parting it out than selling it whole.
battlegraduate09
Gearhead
Mar 18, 2010
610
That's kind of crappy, but understandable. At least the buyer would know coming from you that everything is right and no more half assed work to worry about
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,204
363
At Da Beach
Everyone is bailing out...
Glad I sold my lb7 before the dozen that are now listed in my area hit the market. What in the hell is going on???
