What lift you putting on?
T.C. 4" probably, but maybe 6" I change my mind daily
Lookin good! Leave the flares black, it just goes with the wheels and the stack.
Did you just pull the door trim off?? How easily did it come off and did it leave any faded marks where they were removed??
Looks good
Can you get a bed shot of it?
Eraser wheel is the best thing for removing that glue
You mean were I cut it in and mounted it? I just used a 90 deg.. elbow over the frame and painted it with blk stove paint. I cut the hole with a 4 1/8" hole boring bit so I could save the piece to re-mig in If I change my mind down the road. I used a threaded rod with 2 - 90 deg.. bends to mount the upper braket to the bed while also keeping some ajustability to align the stack. I will try to get a pic later..
The door trim was a real PITA, well not getting the chrome off but the double sided glue they use is really on there. I kept spraying the adhesive remover on there and little by little rolling it off. I tried a plastic scraper that did nothing, I tried a heat gun witch just made it hot goo For me just rolling the adhesive in little balls worked the best, but it still took me all of 2hrs to get them done. As far as being faded I did not notice any shade differance in the paint but even if there was it would only take 10min with a high speed buffer to fade them out..
IMO, Red is a color that grows on ya
Your truck looks good, luv the stack too :coolspot:
