the out come on 650-700hp
Dirtymaxx03
3,109
Caleb if I read your post correctly it sounds like you have it opposite.
It takes xxx amount of torque(energy) to keep the truck moving. If you downshift and make that power at a higher rpm, less "torque" is placed on the rods. Likewise if you make that "torque" in overdrive and do not downshift, more load is placed on the rods due to the lower rpm.
Sent from my iPhone.
makes more sense that way to me at least
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
torque definitely decreases with rpm's like stated above
Lots of opinions and each applications (race, sled, tow, daily driving, etc) will all have a different tuning demand and personal preference.
The theory of lower torque tunes to save rods makes perfect sense from a physics point of view. After all, you don't shift at peak torque, you shift at peak hp (or the range that gives you the largest area under the hp curve - integral).
Can't we all just get along??? we just need a couple of beers and a wide open road/field to play in! :woott:
paint94979
Beer Nazi
Sep 18, 2006
11,715
That sounds right to me
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
This is the way ive seen it for years, it has worked for me and many many others. but if someone from fleece says it isnt tru it must not be. maybe someday the few fleece things ive purchaced will work....i doubt it but maybe.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Its like riding a bike. YOU are the engine, your legs are the rods.
You can go up the hill pedaling slowly, but straining.
Or you can shift gears and pedal really fast, but with much less stress on your legs. :thumb:
paint94979
Beer Nazi
Sep 18, 2006
11,715
LOL I couldn't agree more
carpenca
Dec 17, 2010
168
Yeah your all right... Im just wasting my time, nothing is being read objectively.
Caleb
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Caleb
I'm not putting you down or anything just presenting my opinion as you did.
In your analogy and question above about Truck A vs B, where B ascends the hill without downshifting, and A downshifts.
Truck B puts more strain on the rods, since it has to produce the same amount of power, in less strokes.
Its like lifting 100lbs onto a table all at once VS. doing 25lbs 4 times.
If your arms are weak they will fail lifting the 100lbs, but can handle 25lbs easily.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Yep very true now of we could just make our rods stronger by pushing them like ours legs lol
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
X2, great way of explaining it. Only downside to rpm is oil temp rising.
Sep 10, 2008
1,072
Morehead City, North Carolina
Your analogy makes perfect sense in theory. I couldn't agree more; however, what exactly is Gale Banks trying to explain when he says, "The loads on the crankshaft, piston, the piston pin, connecting rod, and rod bearing during all four strokes of a four-cycle engine increase dramatically with increases in stroke (or piston speed)."?
coker6303
Aug 6, 2009
2,484
40
Houston, TX
Gale Banks was referring to the increase in velocity (piston speed) from TDC to BDC when you compare a long stroke vs short stroke engine at the same rpm. At the same RPM, the long stroke piston/rod assembly has to travel a lot more distance in the same time when comparing the same RPM.
:thumb:
coker6303
Aug 6, 2009
2,484
40
Houston, TX
I did find this, still reading the math involved.
"Engine wear and failure issues...
* Reducing piston acceleration from and toward TCD (point of maximum acceleration) reduces tensile loading of the rod."
Sep 10, 2008
1,072
:thumb:
Unless I'm missing something here RPM is directly proportional to piston speed. If RPM decreases (not downshifting), piston speed decreases. Thus, decreasing load on aforementioned parts, according to Gale Banks's quote.
BUT
Doesn't make sense mechanically....
Torque = Force x radius
Is there a greater force created on the connecting rod at lower RPM vs higher RPM? The duration of the powerstroke would be slower. Maybe the connecting rod endures more stress since there's a decrease in velocity? I'm lost.
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
BUT
Piston speed and RPM are two totally different things. RPM's refer to crankshaft speed/vs. time. Piston speed is refering to acceration of the piston from tdc to bdc. Stroke and rod length are the two main contributors to this info along with piston height. Hope this helps!
