Team Borrowed Time
SBCNX20
Junior Member
Aug 7, 2006
354
53
Central MA
Yep my buddy has about 30 LB7 pistons and I have NO money at the moment, so it I could make it work????????? I'd do it!
SBCNX20
Junior Member
Aug 7, 2006
354
53
Central MA
My other thought is (since its just one piston,and only started in the piston lip maybe 1/4 inch or so) to dremmel it down in hopes of it stopping the crack and just putting her together! TRADE IN!
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
So before you tore it down to fix the head gaskets did you have any blow by? Just wondering if it has a hole/crack all the way through it or not. The way you described the crack on the lip just starting sounds like some mahle pistons I pulled out of my buddies 7.3l. 7 of the 8 had stress cracks on the lips working their way down to the bowl area but none went all the way through yet. Reason I pulled the engine was thought it was a head gasket and ended up being a cracked block.
9,905
151
You will have to check with Todd on this one-the list is pretty large now!!!:rofl:
On a side note, I threw a P0700 last night for the first time.:(
Not good.
