After some ~140,000mile of towing aftermarket fan clutch is starting to go.. Ect runs ~10° hotter than normal.. For temps.. Its 81° out no wind at idle still get nice cold air.
Even on hot days.. Ect never broke 100°C be hard presses to see 97°C. seen 102°C. Higher ECT, means higher EOT, up ~20-25°F) and EGTs up ~100°f, tranns is pushing 100-110° above ambient vs 80-90° above in normal operations while towing... For $110.00 fan has had a hard life.. Been nice if it to start die when the engine killed a piston. Been much easier to swap the clutch then..
AC vent max at idle (700rpm)
