Suncoast 1055 stall speed in 4 low?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
Trent I'm pretty happy with the top end. The gear selection will take some test runs to see if it has the power to pull 4th. I haven't tried it yet. Coming out of the hole better is what I would like to improve upon. With the converter that's in there it will drive through the brakes at 1000rpm in 1st low.
I would go to a 2nd or 3rd gear start. But I would be very scared to let that truck go to 4th gear on a stock bottom end. IMHO you may get only a couple hooks on a good track in 4th if it pulls the rpms down to the low 3,000's. For a stock bottom end you want to keep that puppy reved up in 3rd and go to a bigger tire.
RichLMM
699
North Kingstown RI
me and a friend were talking about this the other day...glad someone else pointed it out..i wont be running 4th again anytime soon lol
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
I also flushed the fluid in my brakes, and replaced the rubber lines with braided stainless, that seemed to help a lot on holding back too.
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
Truck has new calipers pads rotors and lines. I'll have to check the hoses and make sure they're not soft and expanding under pressure.
Rodram2002
Duramax FNG, Cummins Vet.
Dec 17, 2008
5
Bend Or.
Not to side track, but how the heck to you make the truck start in 2nd or 3rd gear? I am assuming this would allow one to run a tighter converter for the street and the start in a higher gear to simulate a looser converter?
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
i was wondering the same thing. I could be wrong but i think its with Efi live.
