I know it claims 2600 rpm but I was wondering how it will stall in 4 low. I need something with a high stall for my pulling truck.
I just tried it in high and I can't get it to stall over 1600rpm without driving through the brakes. The truck has a remote mounted S475 t6 1.32 ar housing. Up pipes, exhaust housing, and exhaust are all heat wrapped.
you need tires and or 4th gear...i switched to 35's went from 4,500rpm down to 3,700-3,800 ran 4th last pull of the year and dropped down to 3,100I'm running a percision converter. I'm not sure on the details as it came in the truck when I bought it.
As far as boost I don't have a gauge in the truck yet. But I can say it pulled 4600 rpm all the way down the track in 3rd low yesterday 2 times. The truck in my sig with stock turbo will only pull about 3k rpm in 3rd gear
Rich I'm not running those sweet racing slics anymore. it has a brand new set of 33x12.50 Baja claws on it now. It's hard enough to maneuver the truck around with those on it. I put the 35s off my other truck on it and it rubbed like crazy. I couldn't even turn 1/8 turn.
Trent I'm pretty happy with the top end. The gear selection will take some test runs to see if it has the power to pull 4th. I haven't tried it yet. Coming out of the hole better is what I would like to improve upon. With the converter that's in there it will drive through the brakes at 1000rpm in 1st low.
I start in manually mode in third , when I leave the line , charger lights immediately and I lock the converter manually with bens controller . About mid track I am getting close to the rev limiter so I switch to 4th and she
Smooths on out for the rest of the run. It pulled 383ft last night in the 7500 street class. I was happy, I am with Trent , try bumping it into 4th
Built motor , duel fuelers , 60's overs , gtx4202r
I pay more attention to my egts than rpm and boost. If you can get 1000* on the line your Turbo will lite every time.
I run a custom 10531 and can stall to 3k or so in 3rd, i let the egts build up to 1000, then do the rest by ear and foot, even building up to 1000 for me, wont light the charger instantly, it takes a lot of practice when you get into really big singles.... I also use one of bens lock up switches and hit it and shift to 4th as soon as it lights.
