Sump and cat filter install---knock off filters?
674
Baldwin filters
Bf7587(1r749) with wix 24770 1-14 $35.00 for the base summit sells them
Bf1259 water sep will fit on the same base
I run sinister/nictane style adapter on OEM filter base and mount water sep on frame rail Between tank and lift up.
Due to a talk with Jake Johnson on FB this is a list of 1-14 thread sized filters and water sep.. Most are STD lengths came off fass cross reference
Baldwin BF 1258 (10M)
Carquest 86528 (2M)
Baldwin BF1214
CAT 1P2299 (6M)
Baldwin BF7546 (10M)
CAT 1R0750 (2M)
Donaldson P558000 (20M)
Donaldson P551025(4M)
Donaldson P551000 (10M)
Donaldson P551311 (3M)
Donaldson P551001(10M)
Donaldson P551313 (3M)
Fleetguard FS1282 (14M)
Donaldson P553203(3M)
Fleetguard FS-1000 (10M)
Donaldson P557440 (6M)
Fleetguard FS-1001 (10M)
Fleetguard FF5320(2M)
Fleetguard FS-1009(14M)
Fram P8334 (2M)
Fleetguard FS-1212(14M)
Hastings FF1079 (2M)
LuberFiner LFF8011
Wix 33352 (6M)
LuberFiner LFF8000
Wix 33528 (2M)
Motorcraft FD818 (14M)
Wix 33674 (2M)
Wix 33405(14M)
Wix 33522 (10M)
674
What Baldwin filters do you recommend to replace the Cat 1r-0750 (ff) and a 175-2949 (ws).
According to Baldwin's website
1r0750.. bf7633, its STD length (7.125")version of the BF7587 (10.5")i run. 2m rating
175-2949.. Is a bf1268, bf1259 (9.5")is longer version of the bf1268 (7.375")
I run the longer versions for increased service interval.. I can push 80-100kmiles before I see fuel starvation issues at ~400hp I have gotten bad fuel and I didn't make it very far before the filters plugged up
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Hopped on the dyno. Its holding 24000 psi rail now on the biggest tune. Before it would drop to 20,000-21,000. Still hasn't been retuned though. Its making almost identical power as before. It did 1214hp before and 1216 after. This pulse width is just too big I believe. Either way, I'm still very happy with it. Trying to get Zach as many logs as possible so he can get it dialed in.
674
Put a vac/boost gauge between last filter and cp3.. It will tell you if the fass 150 is keeping up or cp3s are out running the pump and pulling a vaccum and if so... How much.. And can be done with -3 SS braid line too
