Well, I went to change the oil for the first time since I purchased my LBZ, lo and behold the last idiot to change the oil apparently used an impact to put the plug back in.
I've tried a few things to get the plug off with no luck so far. When I tried using an impact to get it off, it just rounded the head. Then I tried using a pipe wrench with a cheater bar, and all it did was mangle the head even more without budging. The truck had been running for a while before both times, so the oil pan was still pretty hot. I've got some bolt extractor sockets ordered to try as a last ditch effort... any other suggestions? I figure if the bolt extractors don't work I'll try an EZ out, if that doesn't work I can't think of anything else short of swapping the pan.
I thought about using a torch to heat up the bolt some before trying the extractors, but I'm afraid it may just soften up the head of the bolt more and mangle it even worse.
I'm starting to think that this is a really good excuse to order the PPE oil pan.
