stock lb7 vs brian?
bluessmax
Tabasco Injected!
Nov 4, 2010
1,143
Lake Charles, la
Since you changed around these tables make sure you put it in fast learn and then go through the learning process...that'll help much quicker.
5,931
He went out and drove her for about 3 hours last night making the thing shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift and shift, then finally started getting into bigger throttle inputs. :D
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I knew that 'stock' tune we had wasn't stock...that's the first thing we tried! Twas all downhill from there. Can't wait to get it in the 11s! Hehehe
Sent from my iPhone.
bluessmax
Tabasco Injected!
Nov 4, 2010
1,143
Lake Charles, la
yeah, our typical process is if she shifts or runs bad, load the bone stock file. If it fixes it, then the next step is load old tune back in with stock uS, and torque tables. If it runs good then, the next step is to start adding the tables in 1 by 1... If it is something out of the blue that doesnt make sense, we just put it in our little notes bin and refer back to it as needed. It would be interesting to find the specific cause. Sometimes the ALLI hunts for a "out of range" tq value..we try to keep everything at or under 812 (lbz/lmm) and everything else 590 or under if needed. 100mm3 tops on them and 120mm3 tops on lbz/lmm.
hope this helps some others that may have these types of issues reading this thread.
Cheers,
Kory
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I agree with kory. Going to the stock values is always step one to finding out where the issue is. That's where we went wrong and our stock file was not exactly stock lol. Explains why his new tow/econ DSP works so well...it's built off a different tune :)
BLKLMM
<<< Slow Mamba
Jan 31, 2010
2,142
Oceanside
Glad you figured it out:thumb: your still slow Bri:D...you can't retire that truck till you hit an 11;)
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Oh don't get me started on the cummins trucks kory. Seems like 95% of the trucks had smartys/bullydogs/superhogz or what have you on them hahaha
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Whats really fun is getting to operating temp before you leave the end of the street :rofl: :rolleyes:
