Stock IC boots delaminating
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
Anybody else see/have an issue with the stock IC boots delaminating? I blew a hole in my hot side boot, and this is what i found. Im glad that a piece didnt come loose and end up somewhere not needed lol. In one pic i removed the loose section so that it can be seen better.
13,701
756
Yep, I've seen it, but only on that one boot in the same spot. I've only seen it on aftermarket turbo/twin turbo trucks. I'm guessing the higher boost and heat is what is causing it. I replaced mine with a 5 ply 90 degree boot, and it held up just fine. Now I have an AFE tube with the straight boot at the intercooler. It's only a stock turbo, but I think it would be an improvement over stock with any kind of turbo setup.
13,701
756
Mine blew out along the length of it. I'll see if I can find a picture.
Iceman56
Jan 19, 2009
867
Madison, SD
Yes I had three that looked just like that on my LMM with twins. They all blew to pieces, Same boot same thing. I found rubber from those boots caught in my intake heater grid:eek: Like Josh said I also put an AFE tube and boot on and it fixed my problem
13,701
756
Here's a picture of my boot.
attachment.php
RichLMM
699
North Kingstown RI
i had a blowout of mine as well...i took a member on heres advice wrapped it in gorilla tape then heavy duty zip ties...no problems since with the new boot
