Still Toeing in near breaking! bent tie rod
Micheal Tomac
been pulling forever
Aug 12, 2008
273
MI
Yes, I put them on and took them off at the pull. Then I switched to this:
whytry
Oct 11, 2010
282
JFYI a lml has a different centerlink design it does not roll like the earlier models
616samuel
Apr 26, 2011
178
Rockford, Michigan
lml's not for truck pulling, just to get my lly to and from the pulls so i don't have to limp it 60 some miles back home at 45 tops haha maybe someday i'll be able to tune the lml... but not for a long time according to my wife...:jerkit:
616samuel
Apr 26, 2011
178
Rockford, Michigan
Block the rear or weight the front, problem solved:) Did you re-use your Cognito braces?
rear is blocked and i'm in a stock class and we can't hang weights :( i wasn't able to fit the braces on after the link, there's only like 3 threads peaking through with the braces installed so i left them off. But i was also told by a few people that a straight centerlink doesn't really need the braces? but i don't know if that's actually true or not.
ripmf666
15,123
14
47
Wentzville Mo
braces should still fit others that run the 1 1/2" center link get there's on. I'm thinking your truck does not have stock keys in it.
custom8726
2,784
Upstate N.Y
X2, mine fit... wether or not you need them is debatable but I would venture to guess not, I just used mine because I already had them..
616samuel
Apr 26, 2011
178
Rockford, Michigan
alright i'll get under there and through them on then i got 'em, might as well use 'em! on the key's how easy is it to take them out? i've never looked into it, this truck is 98% for truck pulls now should i find some stock keys or lowering keys?
