Haven't posted in a while so just a quick update. Started off this build laying down 1199hp on the dyno and running a 10.28 at 6400lbs before running into a trans issue. Despite the complications, we are still having fun pushing this build to its limits. Water pump failure and some shifting woes kept us from going faster on the last outing. Managed a couple personal bests with a 1.47 60ft, 140mph trap speed, and a 10.18 ET. They just were all accomplished on the same pass . Final pass on the last outing managed a 10.25 @ 117mph as we puked coolant on the big end due to the water pump failure.
JoshH got a wild hair the night before going to the track and decided to strip it down. We pulled 900lbs out in about 2hrs. Race weight ended up around 5500lbs with a driver. We already have the fiberglass front clip, still need to order the bed sides. And yes, it is getting a cage. Scheduled to drop off the first week in April.
Current setup is a box sxe 472/87/1.0 & Forced Inductions 491/100/1.45, dual 10mm Exergy and S&S pumps, and 250% F1 Diesel injectors. Steed Speed manifolds and 2-1/4" uppipes. Long block is a SoCal Diesel assembly with a narrow rod billet crank, Carillo rods, forged pistons, 9100af cam, stage 1 heads, girdle, etc. Running a Goerend K converter at the moment, billet input and output, billet c2 hub, stock planetary. JoshH will have to shed some light on the clutches.
https://youtu.be/qK7gz9z7RNs
https://youtu.be/CZbeBwrX4Bs
https://youtu.be/n6rJxFbftiU
https://youtu.be/jgU1bs43LFA
https://youtu.be/_xLG88K95Wk
