Stereo ???'s
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,215
365
At Da Beach
I wouldn't ask any advice from someone who thinks that jl audio is the "best in the biz". While they are pretty good they are far from the best.
I am speaking from the marine industry aspect, not car audio. I know there are other brands for car audio but I am unfamiliar with them and of what quality their products are. Please elaborate...
And the advise I was offering was for install tech...
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Leave the dynomat alone gut the stereo speakers amps etc and label wires. Get a d batt and pop ur speakers ( pos speak wire to batt ) they should suck in when you do this if I remember. Just come over with great beer I'd do it for fun. You have to pull it all a lot of guys sell trucks that had stereos but pull amps and replace with cheap shit (( I did on a trade in). Never buy used unless from a autophile Like I said b4 I almost bet I have the best sounding 05lly crew anywhere
I bet mine sounds way better
TQMONSTR
Nov 19, 2009
161
Canada
A huge part of a great sounding stereo is the install. A great install with average gear will sound better then an average install with great gear. Seeing as your truck is full of Dynamat i'd say you're off to a very good start. Have you thought about a center console sub install?
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Na no center console sub. one 10" is plenty for me Im not out to think I have the best sounding truck, I dont even drive it :roflmao:
RobsDmax
832
Arthur, Ontario
im gonna go out on a limb and say it probably will be fine with your boston sub, and a amp that gives enough to power it. then call it done :thumb:
Great White
Great White
Jul 16, 2009
93
Show Low Arizona
I have a question for all of our friends in Arizona. You have made me revisit wanting to upgrade my Stock Bose system. Do any of you know of a high end quality professional shop in the Phonix area you could recommend?
J_Stone06
Wasn't me...🥴
Oct 13, 2012
347
3
Nowhere, KS
I do also know a little about the stereo topic. Make sure you don't run bigger wires than the input is on your amp. It defeats the purpose to run a larger gauge wire and then have to trim it down to fit it in on the terminal block (s). Something else you may want to keep in mind, is running a capacitor. Typically, you want to run about a farad for about every 1000 watts. I know some companies make digital hybrid capacitors that you can run multiple amps off of, but typically cost a little more $$. Also, if you need just a single channel amp, check and see if the one you have is bridgeable (if it has more than one channel), chances are it probably is. I don't know everything about stereos, but this is just my :2cents: .
5,911
House of sound off rose garden and i17 do nice work. They originally put the system in my truck when my dad owned it.
