Steel Pistons?
Diesel power
Jun 2, 2008
855
maryland
Show us 5600 then.
I posted a 5250rpm pass log years ago at a national event.
Surely you can beat that. (not idling, let's see it shift at 5000+.)
This is all i could get to load. Can you point out all the issue's? , 5.43 @ 130+ run :thumb:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Thanks!:thumb:
So you have no problems at 5600rpm and 33 psi boost for <6 seconds.
And this is your basis for determining that Mahle pistons are garbage, and that you are a master engine builder.
Dial it up to 75psi and get back with us, eh?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Without the sarcasm:
For 1/4mi dragracing in heavy trucks, for sledpulling, for sustained high-power towing, and for land speed racing, the loads on the piston are far higher than anything you've personally dealt with, unless you've got a Dmax pickup that you are keeping quiet about.
And the Mahle's are surviving in those applications, but not indefinately. Much like factory rods, the OEM pistons are a known weak point. A piston that can survive for long periods of time for those application (like aftermarket rods can) would be a good thing.
Truth is, none of the high HP Dmax builds are showing acceptable lifespans IMO. Failures are pretty common. Just because your application hasn't shown issues isn't proof since the limited duration and short life you've seen. You simply don't have enough seat-time at 750rwhp+ to evaluate part life.
Until somebody runs steel pistons, we won't know how they do either. Perhaps they won't be a cure-all. But perhaps they will. Dmax'rs have been cracking and melting pistons for a very long time now. Arias have been in use now for ~4 years IIRC. Most the news about them is good news (your car isn't old enough to be good data), but there isn't a lot of them out there yet. Obviously I'm going to try and add to the knowledge base when I run them. Your evaluations of products is always the same:
"I have these parts, so they are best. Everything else sucks because if they were good, I would run them."
That logic might fly in the Dodge world, but Dmax folk tend to be a bit more scientific.
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
Steel pistons will be a step backwards. IMO. More weight, More cost, More eventual problems elsewhere in the engine.
Aluminum pistons are fine, you just need to use the right materials and build according to what you are doing.
If aluminum was a issue in racing top fuel and every other form of racing would not use them. Our diesels dont see 25% of the stress a top fuel engine does. Not even close! Aluminum pistons are not the issue.
There are three reasons aluminum pistons wont work for you.
(1) Your builder is not qualified to properly build a engine with the correct parts combination.
(2) You or your tuner is not qualified to be writing tunes for a racing engine.
(3) Both of the above.
So, you must be some miracle worker and tuner. Try a bunch of 1/4 mile passes first. Steel pistons would be better for longevity, and ability to withstand lots of heat cycles. Over the road trucks use steel pistons for this reason. I was at Shieds last year and spoke to the guys with commonrail cummins funnycar, and they have not anything but good things to say about the steel pistons; and you all know how commonrail cummins engines like to eat aluminum pistons up. My oppinion is that the little extra weight penalty would be well worth it, if I didnt have to pull the engine apart all the time due to melted pistons, worn out piston ring grooves, and lastly, I would be able to put miles on the engine without worry.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
What's up with the lateral g's and acceleration g's? Was this on a dyno? Do you have any track logs/picture you can share?
Still didn't get to 5600 :baby: just picking, thanks for the post.
Diesel power
Jun 2, 2008
855
maryland
if you look at the cursor it at the end of the run, right when i shut it off. hence the low boost, accel and lateral g's
that run had over 2.5 g's of accel in first gear (after it recovered from it's bog of course) and just under 2 g's in second and still a g in third.
lateral g's on that run were over .5 g's on both sides of center lateral due to the rear end being so loose during the shifts
With all the tire spinning and tire shaking present, it did well.
The rpm and drive shaft lines should be smooth as glass when you have a good run with everything close to 100%
here is a vid of that run http://www.youtube.com/user/ngmdieselracing#p/a/u/1/kAHP6n53iFw
listen close you can hear the tires hoppin/shakin in first and second gear
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
I think I'd rather see a log than a video. Thanks in advance.
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Wade, So your program is in the very early stages of development from how it sounds.... is there plans for 1/4 mile racing this year seeing how you seem to have half the race sorted out. Would love to see those logs when this happens, nice log sheet and thanks for the share of data.
Diesel power
Jun 2, 2008
855
maryland
i've ran a few 1/4's last year in the 8's, only problem is that i shut off at the 1/8th mile and coasted throught the 1/4...
This year will be 1/8th mile first then 1/4 mile, looking for records.:cool2:
Testing to commence very soon.
