also interested in the tct swap. are you going to run true parallel twins, one off each side, or compound them?
They will be mounted right where they are now.
Couple more pics
what size pipe are you using to feed each turbo exhaust?
also, did that bellow come with a 1 in 2 out already or did you make it?
For starters the charge pipe blew out the s475 on every pass. I knew I had to weld a bead around it for the clamp to catch but never did. Rail pressure was dropping to 19,000 on the bigger tunes and was 20,000-21,000 on the 3 tune and on top of that the brakes were garbage which made staging nearly impossible for Kayla. The truck has been sitting for a while and has some bugs to work for sure.
You will probably need to use a brace to the Ac compressor to keep the charge pipe on unless you vband it.
Sent from my XT1080 using Tapatalk
