Mini spool fits in the g80 carrier, itsfairly easy to install as well, held a full season in our 850ish hp 2.6 truck, even with duals on the rear for a hand full of pulls! We are upgrading to tonys 38spline setup for next year!!
PM sentall very good points and I don't think anyone has ever questioned the quality of the products you sell, or your customer service, or your internet presence, all of which are top notch. If I was limited to a stock rear and had the horsepower, your spool and axles would be going into my truck. A fellow puller has your setup and it has been bulletproof.
Does the mini spool install in place of the g80? How hard is it to install one? I would be having a shop install this and a gear change at the same time. I really liked the simplicity of a full spool just not the price.
I hear ya. I spent a ton of time last year putting on stuff and taking it off into order to pull. And had a few break downs too. It would be nice to just have a trailer queen to get it setup and leave it all pulling season. Did they change the rules for what rearend you can run in altered this next year?
Material testing can be done without cutting them apart. Yukon kits look differant because they cheapened them up and the price reflects that.Ive never broke Yukons 4340 axles, just the lower grade ones, ive twisted the 4340, but they will twist to a point, and still hold up. Klikkel axles will twist too. But i will say i still like the dual spline set up better. Also, Yukons kit looks nothing like the ones you sell Tony, im not sure what could have been copied unless he cut them open and took a material sample.
Still have the mosers??
With all the kits i have sold in four years i have only had one shaft break and that was from a ring and pinion failure.
That was the only failure and there was a ring and pinion failure before he bought the truck. Does that make what i have junk?:hmm:What about Marvin Gillfillan at ts 2 years ago? He did not break a ring and pinion there.
Theres alot more big trucks out there using my axles with zero failures.
I dont question Yukons quality. I know what it is and i have the failure numbers direct from Randy's. Your previous post sounded like i may have forgot his or as if you were trying to catch me in a lie. I was raised better than that.I beleive if anybody questioned quality it was you with yukon. Yet i have had 0 failures with their good axles. Wakeman also runs them, so they are obviously not junk either. Like i said, i like steves design better, but for the price, ill buy the proformance set up.
Sorry but if you read his post again it looks as if i forgot one. If he was trying to clearify it should have been worded like "Was Marvins the axle failure you refer to?"Looks to me like he was just trying to clarify as I heard the same story. Still a great track record.
Rhall's always trying to drive a knife in my side... Not sure what i did to him but i sure am sorry...
Play nice boys...:hug: Now, from where I stand you are all correct but it comes off wrong or missunderstood. Tony is right about the quality difference as we have failed quite a few of the yukon 38spine axles and a Grizzly locker too. We haven't had any issues with Tony's but some customers thought they weren't worth the extra coin and it bit them in the ass. As for the injectors, when you swap between two designs that flow the same amount and one set works and the other doesn't, pretty cut and dry. I have trucks running them but getting them to work properly is not easy. On LB7's we have no choice but to deal with them if we want over 100% but on the newer trucks they are not the nozzle of choice. Yes Rob, it IS your job as the consumer to ask the questions needed to help you make the best educated choice to fit your needs. Tony and I both take stuff sometimes too personally but that is how we are and it is also what drives us to be the best that we can for ourselves and our customers. Our customers will tell you the same thing. And you are right with the questions as that is how you got your truck where it is, in the lime light so congrats on a great runner!
