So this happened...
Digmax
289
Looks to me like he run it low, that causes the air to heat up and will soften the sidewall. Low pressure=blowout
Sent from my C811 4G using Tapatalk
fast03
1,201
60
Rancho Cucamonga
don't drive with known tire issues period! wtf.... your life or someone else's life is worth more than the few dollars to get a flat repair
13,681
723
And have a higher weight capacity than one 245/75/16 E range tires
The 315/70/17 I have are D range and have a 3119lb rating
Hell the 225/70/19.5 F have a 3640lb rating which is less than a 285/75/16 E range that has 3750lb rating
Yep. A load range E tire is good to a maximum pressure of 80 psi, load range D is good to 65 psi, C is 40 (I think, haven't bought any load range C tires for a long time), and XL tires are good to 50 psi. Tire weight ratings come from their size and load range. A 265/75R16 tire will have the highest load rating in load range E followed by D, XL, and C respectively. However, as you add more volume and contact patch to the tire, the weight rating goes up, so a 285/75R16 in load range D would probably have a higher weight rating than a 265/75R16 in a load range E just like the 305/50R20 does in the XL rated tire.
This scares me because ive had plenty of nails in my winter tires that ive left in for weeks and its never cause a blow out like that. Coincidence maybe? Or like stated they are the correct load range
Your winter tires must not have been losing air. If a tire gets low, it heats up faster and makes the tire weaker. I'm sure the roads are also hotter right now than they are when you run your winter tires which doesn't help the tire any either.
Well regardless 4 different big chain tire places refused so it's obviously a common trend
That's more of a CYA legal/insurance thing than it is some sort of law. Tire stores are stupid about this in my opinion. If a tire meets or exceeds the weight rating of the stock tire, I see no reason why they shouldn't mount it on your wheel.
15,681
Think about the lawsuit part of this equasion. If there was an accident the tire store would get nailed pretty bad. Why in the hell would they take that chance?
13,681
723
It would be pretty easy to argue the weight rating of the tire meets or exceeds factory equipment, but I understand common sense can be lacking in the judicial system as well. The stupid thing is I bet they will install a smaller load range E tire with a lower weight rating than factory.
Porno Joe
513
South of Pittsburgh
I'm with this dude.
If I had to drive home with a tire I knew had a nail or was leaking (Which I have) I'd be limping it home, not doing 70 on the highway.
and you commented that you've around for weeks with a nail in your winter tires? That's like wiping your ass before you shit- doesn't make any sense!
CentolaCCSB
It will probably break
Nov 2, 2015
322
Mass
I'm with this dude.
Well i understand all sides of it, yeah I probably shouldn't have been doing 70 but i was just trying to get it home asap riding in the far right lane with no one really near me. Silly i know. And i guess i just never understood how dangerous it was to have a nail in the tire. And what josh said makes sence roads arent as hot in the winter time. Lesson learned
CentolaCCSB
Nov 2, 2015
322
Mass
I'm with this dude.
Im sure someone on here has driven around with a nail in there tire without knowing for a few days maybe even a week..
Dozerboy
4,892
470
TX of course
You guys kill me. Most people drive around with nails in there tires for days ATLEAST. Couple days go by tire goes low maybe they take it to a tire shop. They let you know you have a nail in your tire and fix it. I've had nails in my tire for months years maybe. Why? They didn't leak! Don't go lecturing about nails now. I've never had a tire blow on anything but a semi.
Centola you might be missing the point. If you would of assess the leak and if it wasnt to bad you could of just put air in it and been fine. I bet you had 10-15psi at most when that tire blew. Probably been low days.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Discount Tire refused to remount the wheels/tires on my younger brother's 2006 LBZ last year unless they removed the 2" spacers,(they told him when they removed the wheel/tire) talk about CYA...
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
To get around the issue of them not wanting to mount tires, I took the wheels and new tires there separately and had them mount them, they can't be liable for what they don't know.
Dozerboy
4,892
470
TX of course
I like discount they have been pretty good to me. They actually wouldn't put tires on my truck when they found out I have anti seize on my lugnuts. I told them fine I'll go get my tires somewhere else. They not only wire wheeled and brake cleaned the anti seize off the studs. They gave me free locking lugnuts since they didn't think they could clean them. But I'm buying tires there all the time too.
Now after I buy tires there before they TQ the wheels I just ask the tire guy not to TQ them all the way because of the anti seize.
Now after
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Not true, at least for the one about 2 miles from me, I did the same thing all loose tires and wheels, but, they (Discount) checked the tires for the weight rating before mounting them on the 8 lug wheels and everything was correct. Discount has been scrutinizing more and more in the last few years..
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
That's why I despise discount tire. GVW on this truck is 9200 lbs. I have 10,500 lbs worth of E-range, 10 ply, load carrying capacity on these tires....yet discount will not mount them. WTF!?!
515
I picked up a screws in both rear tires of my 79 Malibu.. bought tires but they didn't have time to swap them out, so swung by discount tire to get new ones put on. I use 1/4" spacers on the rear.. you'd thought I was trying to kill one of their guys for the hell that raised over it!!
Not to mention they bitched about load ratings, the 275/40/17 have a 1600lb rating car weighs 4100lbs of that rear axle weighs 1900lbs.
