So this happened...
CentolaCCSB
It will probably break
Nov 2, 2015
322
Mass
So i was packing up my tools for the day after a long 11 hour day and i happened to see a good sized nail in my tire. Didnt think much of it said meh ill get it patched tomorrow moring no biggie. Heading home im on the highway and im about 8 miles from home and i start to hear some weird road noise. Look in my blond spot mirror and look at my tire seems fine so i keep going. Noise gets louder and louder so i decided i need to pull this girl over and see whats that noise. And sure enough as soon as i get into the breakdown lane BOOM! Truck falls on its face and smoke is pouring outa the rear end of my truck. Get out to see and saw some carnage.
So what im thinking is that from the nail being in the tire it was slowly letting air out and it got so low that it couldn't hold the weight of my truck anymore and it just gave out. Please tell me im right and i shouldnt worry anout the other 3...
chevor
Highway hauler.
Sep 17, 2015
192
On the Road
Low pressure do to leak. While rolling the tire builds up more heat than usual causes rubber to fall apart.
CentolaCCSB
Nov 2, 2015
322
Mass
No! Suprisingly the wheel is fine! It was rolling on the little bit of outer side wall that was still attached to it, it finally let go at like 30 when i was trying to stop in the breakdown lane.. Im sooooo glad it didnt happen while i was rolling at 70mph
Dozerboy
4,892
470
TX of course
I agree with Chevor the tire being low on air caused it to blow. Damn lucky it didn't go at 70.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
305/50/20 are E range and. 3088lbs capacity..
Low air from leak caused tire to overheat and fail like chevor said.
I wouldn't worry about the others
I'm curious how that size tire is rated at 3088 lbs, yet a Toyo MT in 33x12.50-20, whish is an inch taller and half inch wider is only rated at 2601 lbs. WTF?!!
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
I'm like 99% sure they are D because 4 shops refused to mount them on an 8 lug wheel stating they legally can't mount D rated tires on 8 lug wheels.
515
They are lieing to you. It's company regulated due to the monkey wrench turners tire discounters, discount tires and others are PITA and a bunch of idiots that can't think for themselves in common sense fashion..
I care less about said load range and more about stated weight capacity.. I've seen Ds rated for more than Es..
Right off their website not to 420s
13,681
723
Those are not a load range E; they're an XL rated tire.
515
And have a higher weight capacity than one 245/75/16 E range tires
The 315/70/17 I have are D range and have a 3119lb rating
Hell the 225/70/19.5 F have a 3640lb rating which is less than a 285/75/16 E range that has 3750lb rating
CentolaCCSB
Nov 2, 2015
322
Mass
This scares me because ive had plenty of nails in my winter tires that ive left in for weeks and its never cause a blow out like that. Coincidence maybe? Or like stated they are the correct load range
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
Well regardless 4 different big chain tire places refused so it's obviously a common trend
