So I think its time for some HG's
wsmithduramax
<--- Home Made!
May 4, 2009
474
Windsor, CO
if you just done it last year,it should of lasted a longer that this. . .
thats what I would have thought, but then again it was an ac pump number not the GM pump one but who knows, it seems like parts these days are failing fastere and faster even when they are new. I think I'm gonna run a few more test tonight, and then maybe just for shits and grins throw a water pump on there, and then I will have eliminated most of the problems it could be.
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
Thanks for the added info Wes, does sound like another issue at this point other than HG's. Got my fingers crossed $180 water pump is all u need.
wsmithduramax
<--- Home Made!
May 4, 2009
474
Windsor, CO
New two piece water pump
So I'm almost sure that this is my overheating problem. looks like I got one of those NEW two piece water pumps:D. Dunno if anyone has seen this before, i've heard of the gear spinning on the shaft, but not the impeller. Anyways my dumbass didn't bring home a housing with me and as you can see from the pics I should prolly replace it. So gotta wait till monday. Hope this fixes my problem.:thumb:
wsmithduramax
<--- Home Made!
May 4, 2009
474
Windsor, CO
Yea I think its safe to say that as well. I just wish I wasn't such a dumbass, I even had the part number for the housing and thought there would be no way that could be screwed up. Guess that goes to show what i know:confused:
wsmithduramax
<--- Home Made!
May 4, 2009
474
Windsor, CO
I do have one question about the welding the gear and the impeller, should I use a mig or tig welder or does it even really matter, and should I weld the whole seem or just a tack on each side so I don't get to much heat on it?
maine04max
Dec 11, 2008
1,009
some have good luck others dont . I have tried mig and tig and welding all the way around on both impeller and gear neither worked for me . as i said before first failure was impeller just a tack mig on both sides . second was tigged after taking out extra material on both sides near the shaft and tigging it ( lasted less then 200 miles) . there is a thread with more info on it here . both sweetdiesel and othergrl posted some good info on water pump failures . iirc Trent drillls the pump before he welds it and that has worked for him .
wsmithduramax
<--- Home Made!
May 4, 2009
474
Windsor, CO
Yea I've read several threads about welding the shafts. I asume when you say "trent drills the pump" you mean he drills a cross hole in it and then puts in a roll pin or something is that whay you mean?
dirttymaxx
Nov 15, 2010
334
sharpsburg,ky
hey now i like roll pin ideal!! never thought about that. . .all i did was just weld the sean all the way around the shaft,low heat both sides
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
I installed a roll pin kit for a guy who was possibly going to install a supercharger on his LS7 vette, and the kit he supplied came with the pin and drill bit. At any rate it just had you drill down the seam of the crank and balancer and drive the pin into the new hole. Should work good if things aren't hardened. I'm currently installing an LBZ pump on my LLY. Only had to modify one tab and heat and lube the hose to put it on. Next time I'll modify the inlet for the proper hose size, if i have any issues. Glad my % were wrong and appears to be an easy fix!
maine04max
Dec 11, 2008
1,009
No , I think what he did was drill a good size hole and then welded it . even if the weld breaks around the shaft it sill works to keep everything together like a pin
wsmithduramax
<--- Home Made!
May 4, 2009
474
Windsor, CO
That makes sense. I think dad and I are gonna set it up in the CNC and mill a hole in the end of it and then press a pin in there and then tig weld the end of the pin and the main shaft and the impeller together. and then do the same on the gear side. Maybe that will help hold it together :thumb:
