If u spend most your time on gravel, it will be better then pavement. U cant beat tracks in soft conditions. But when its frozen or dry, tracks are very rough, shake everything and dont bite like tires.
wonder how hard it is to have the emissions fall off
Andrew this should handle all your dirt work needs...Cat 994 will do anything you want in one pass :thumb: :rofl:
If you go tire machine Grouser makes a great over the tire steel track setup and they can be rebuilt. Look for them on CL used if you can wait it out, bolts, nuts and bushings are not that expensive.
If you decide to go with the track machine, look into the snow tracks Bobcat offers, night and day difference. You wouldn't have to use the Bobcat brand if you didn't want to as the aftermarket world sells them now as well.
When it comes to inspecting the U/C on a track machine look for the obvious sprocket wear(teeth coming to a sharp point). If you see this the tracks are most likely worn out as well. It is always a good idea to put new sprockets on if replacing tracks unless the sprocket is in good shape. Check the wear surface of the idlers and rollers. Honestly, when it comes to the U/C the wear parts are somewhat expensive but what you can't see is the real issue...the drive motors. If you wanted to get real serious, take the machine to a dealer and have the pressures checked as a drive motor is pry over $4K these days.
Good luck and let me know if you have any other questions.
I love the M-series Bobcats.
We have a T770, T750 and an S770 all loaded but the S770 is the only one with hi-flow.
I love my T770. I demo'ed a 289C before we decided on the first T770 and wasn't really impressed. The D series has awful sight lines to the rear and I hate the tier 4 emissions the new machines have.
Looking into it more I see the standard cat out works the standard flow bobcat, but the hi aux flow bobcat flows a lot more. Also noted that the bobcat can lift more, but seems like the cat might be a little better at pushing. I think it might come down to price, most of the hard work will be with the bushhog and a dozer blade so don't care about the lifting so much
lol ok! The day I close on this land I think I'm going down there and getting one. Right now leaning towards the CAT unless the bobcat is a lot cheaper
Any of you have experience with Komatsu D31s?
http://www.machinerytrader.com/listingsdetail/detail.aspx?OHID=9290617
Thinking this and a small 4x4 tractor with a loader will work better for me
